RCU Forums - View Single Post - adding color
Thread: adding color
Old 09-12-2010 | 06:36 AM
Augie11
Default RE: adding color
ORIGINAL: scale only 4 me
Well when you mentioned Monokote as an option, I figured they might be covered in monokote already
''Glass and Paint'' is a two step process, you cover them with fiberglass cloth and resin,, then paint.
Since now it seems they already have silver paint over fiberglass or silver gel coat, all you have to so is paint,,
I would wash with warm water/soap to remove any grease or mold release agents, then lightly sand (420 grit) to scuff up a little the area you'll be painting,,
I'd also do a ''test'' area to make sure the paint you used isn't going to eat the paint that is already on the floats
good luck
That's the way I'd do it as well. Just make sure your paint is fuelproof or, if it isn't, give the floats a final coat of clear that is fueldproof.
