RCU Forums - View Single Post - LIPO problems noob in training
Old 09-13-2010, 02:32 AM
genitor
Default RE: LIPO problems noob in training
Did you check your motor and esc temps. at all?
I'm thinking that if you were using too big a pinion your motor would overheat also.
Also check that your drive-train is running smoothly. I once had a battery overheat because a busted bearing was causing the motor to overwork.
