Need help identifying
WI
I went to a swap meet today and found an autogyro to take home, but I don't know what kind it is. The guy I bought it from said that it was a kit, so maybe you guys can help me out. It's a tractor engine with a single two bladed rotor. Each blade is 23" and the fuse is just under four feet. It's made out of aluminum that's riveted together. The tail surfaces are made of coroplast as well as a piece around the rotor mast. Any ideas? I'll try to post some pics.
I think its a Kombat Kopter. Made in Louisiana somewhere.
I've never seen one in person.
I'm sure its a kombat kopter..
http://kombat40.com/gyro.html
1135 Florida Street, Mandeville, Louisiana 70448
http://kombat40.com/index.htm
mickey
mickey
WI
The webpage doesn't have much for tech info on it. Does anyone know where I could get it? I don't know how/where the servos install, where the thing should balance... If anyone has some good close-up pictures that would help immensely. Thanks.
Yes I have a Kombat Kopter 40 get in tuch with me email [email protected]
I can tel you all you need to know about it. I have the plans and C/G position.
