 WARBIRDPROPDRIVE UPDATE >
Old 03-05-2005 | 11:42 AM
My Feedback: (26)
Default WARBIRDPROPDRIVE UPDATE
Hi All:
New updates to the Warbirdpropdrives.com website, with more info on testing and installation pictures of the drive and Kelvin's Scale Exhaust.
The side frames of the drive will be modified to make them longer, eliminating the need for the little standoffs you see between the drive and the firewall.
No need to cut the firewall to make it all fit. We will most likely go to a 2 strand belt after testing proves that we can successfully run a two strand setup. If we have to go three strand, it will fit.
See you at Toledo!!
Joe
Old 03-05-2005 | 02:47 PM
RickVB's Avatar
My Feedback: (24)
Default RE: WARBIRDPROPDRIVE UPDATE
Joe, you forgot to say this time what prop you were using. Blades? Diameter? Variable or fixed?
Old 03-06-2005 | 02:34 PM
My Feedback: (26)
sorry rick: i thought i put all that info on the website.
all tests so far are with a Soloprop ground adjustable pitch prop. 3 blade, 26" diameter, 24" of pitch.
hope that helps...
