Onboard video: multiple angles with one cam
So last weekend I decided to mount a MycroCam 720 on my new Killer Hai flying wing. Made a few flights with the cam mounted for forward, side and rear view. Then I edited segments of these several flights into one "virtual flight" with multiple camera angles. The difficulty obviously was to find cutting points in which the airplane is (more or less) at the same position, as seen from the airfield, and flying in the same direction in both of the joined segments.
Next time I should work out something like a pattern program and try to make the same flight several times, that would make the editing so much easier. But I hadn't planned that far ahead. Anyway, for a first try I'm quite satisfied with the result. See for yourselves.
https://www.youtube.com/watch?v=kXrWO4hh7Wo
I did exactly what you did in regards to mounting a camera at different angles and editing it into a single video. And I also had issues matching video angles like what you've mentioned. But I think what they do in the movie industry is they will mix in footage of the plane shot from either the ground or from another aircraft between footage shot from the plane at different angles.
I shot my first ever aircraft video last Saturday and edit it within a day or so. The aircraft I shot from is the Parkzone Stryker and I used a Mobius Actioncam.
