Aerial Photography and Video Discuss the growing field of aerial photography and aerial video right here!
900 MHz, legal or not
Old 01-14-2004, 12:05 PM
jjmav
Default 900 MHz, legal or not
Ok, so 1.2 Ghz is not legal without an FCC license. does that mean that 900 Mhz is also not legal?
Old 01-14-2004, 04:09 PM
mr.rc-cam
mr.rc-cam's Avatar
Default RE: 900 MHz, legal or not
As discussed in prior forum discussions, the "1.2Ghz" spectrum is NOT totally illegal in the USA. For example, licensed ham's can officially use 1.24Ghz to 1.30Ghz under the FCC Part 97 rules.
The problem that has come up is that many of the popular imported video Tx's found on eBay and other sites are not really as advertised. Instead of being "1.2Ghz" they are actually using the 1.00Ghz to 1.19Ghz area, which is reserved for commercial aviation navigation in the USA (NAVAIDS). These Hong Kong products use this {USA} illegal RF spectrum because it is legal in THEIR country.
This issue can also extend into "900Mhz" products, so you need to know what you are buying. Allowed ham freq's (license req) are 902.0 to 928.0 MHz and several hundred watts are possible. The FCC Part 15 registered devices on 900Mhz (or any other video Tx frequency) are license free and can be used by anyone. These products (video senders, cordless phones, wireless data, etc.) transmit using average power levels that are less than 1mW (.001W), which is too low for practical use in our R/C video application.
For more info on the spectrum allocations, please see this chart: http://users.skynet.be/on1dht/ibandguide.htm
The "legal" questions really depend on what you are asking. If you mean "Is it legal to use any of these unregistered (not Type-Accepted) video Tx's without a license," then the answer is No. However, if you are asking "Can I use these video Tx's with my valid ham license," then the answer is Yes, but only if the device complies with the Part 97 rules.
The best course of action is to earn a ham license. It opens up a world of RF video products to you. The license is nearly free (test admin cost is usually a one time $15 or so) and is good for 10 years. Renewals are free. The test questions are not hard. You do NOT need to know Morse code. The technical stuff you learn to pass the test will help you obtain better performance from your wireless video equip. And best of all, following the ham rules prevents disruption of the other hams that are operating legally on the shared airways (they are hobbyists too, just like us R/C'ers).
Old 01-14-2004, 06:49 PM
kh6oo
kh6oo's Avatar
Mr. RC is correct. Also be aware that most freqs above 1.2 Ghz band are "Freebands" which anyone
can use.
Tom
FCC Ham KH6OO
Pearl Harbor Hawaii
Old 01-14-2004, 06:50 PM
kh6oo
kh6oo's Avatar
BTW, there is an advantage to getting licensed though. In addition to the other channels, there is also equipment availability. 1.2 and 900 MHz has a lot of easy to find gear through the ham outlets.
Tom
KH6OO
Old 01-14-2004, 06:59 PM
mr.rc-cam
mr.rc-cam's Avatar
Keep in mind that the equipment above 1.2Ghz is also regulated by Part 15 and Part 97 (as well as part 90). The license-free video gear (e.g., FCC Registered equipment) in these other spectrum areas is very low power (under 1mW). To use more power (which you will want), you will need a ham license (Part 97) or a commercial license (Part 90), depending on the application and equipment used.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
