Frontier Senior specialised video plane.....
MO
The end of the month I'm going to be getting a Frontier Senior. I'm going to sit the dyhedral flat,and attach an engine, fuel tank and throttle servo in a pod on pylons in the middle of the wing. I'll be using a Thunder Tiger .61 Pro. Then I will cut out the "chin" of the cowling and install my camera and pan servo under that.
I'll also have a digital camera mounted on the side of the fuse on a swivel mount. All the batteries to run the system, servos, and the 2.4 Ghz transmitter will be held internally, with only the antenna extending out the side of the plane.
My video camera will be completely unobstructed and able to pan from center to side to side. I might also put a spare camera on top of the wing, facing aft, and will hook that up in place of the nose cam for chase shots.
Outta be fun.
Outta be fun.
MO
RE: Frontier Senior specialised video plane.....
It's made by world models. It's a bit cheaper than the Kadet, and a little heavier but still flies pretty much the same.
I was going to use one but I got a really good deal on a Sig Kadet instead.
