Aerial Photography and Video Discuss the growing field of aerial photography and aerial video right here!
wireless on T-34
Old 04-05-2005, 06:06 AM
^^_FaWaZ_^^
Default wireless on T-34
hello, i just bought a wireless cam for my 46. T-34 mentor and im having problems on where to put it here's some ideas :
1- in the cookpit
2- under the airplane behind the nose wheel
3-on the wing from up
any ideas will help allot, thanx.
ps. it needs a 9v battery on board so we have to be careful not to mess up the CG.
Old 04-05-2005, 08:53 AM
redfox435cat
redfox435cat's Avatar
Default RE: wireless on T-34
Always look cool from the cockpit
Old 04-05-2005, 11:42 AM
^^_FaWaZ_^^
i c, but the cockpit will only give you forward view !!, i need forward and a little bit down.
Old 04-05-2005, 07:20 PM
Fubar-One
Fubar-One's Avatar
You can velcro it to the side of the fuse. Make a lite ply or hard balsa "wedge". Glue the camera to that then velcro the whole thing to the fuse. The wedge will add sideways to the view and you can velcro it to whatever amount of down you wish.
When I use a camera on my Kadet Senior ARF, I attach to a hard point I added between the innermost ribs on the left wing. Also has a cutout for a servo allowing full pan.
I am not using one of those "All-In-One" cam/tx systems tho.
I have had great success with both methods, but both entailed cameras what were wired separately from the tx.
Should work ok for your system.
Old 04-05-2005, 11:45 PM
redfox435cat
well you can add another channel and make a 60o turret hook it to the flap or a y harness and hook it to the rudder and be able to see the ground very well in a 30o bank
just a thought
Old 04-06-2005, 09:30 AM
^^_FaWaZ_^^
ok thanx anyway guy's but i disided to tint the canopy so no one will see whats inside and put the camera in there and open a little hole for the camera lence to come out...
hope u like it [8D]
Old 04-06-2005, 01:21 PM
randall1959
randall1959's Avatar
If all you want to do is aerial video, unless you plan on filming a dogfight or some other scale event, the best thing would be to put the camera on a non scale plane. Then, it would be more a matter of mounting the camera for the right view. After all, you can't see much of the plane with the camera.
A decent trainer makes a very good aerial platform. You could mount the camera system on the outside of the plane in lots of places in order to get the best viewing angle. The setup you are going to try will not give you much more to look at than a spinning prop.
Anyways, just a few thoughts.
Do you have some purpose in mind that needs to have a T34 as the AV plane?
Old 04-06-2005, 04:23 PM
^^_FaWaZ_^^
coz i was thining of putting it in my extra 300s but then i crashed it[:@] and the only plane i have left is the T-34 so im putting it in there and i don't want to just take aerial video's im also gonna do some aerobatics flatspins, hammer heds... and some dog fight's if thats neccesery to make a cool movie
Old 04-06-2005, 07:40 PM
Fubar-One
Fubar-One's Avatar
My first attempt was mounted on a popsicle stick rubberbanded to the fuse of my Tower Kaos.
[link=http://www.fubar1.net/movies/wireless/videokaos1.wmv]Video Kaos 1[/link]
Not good results!
Old 04-07-2005, 06:30 PM
^^_FaWaZ_^^
wow dude that realy sucks there'a allot of vibe's is that a wirlesscam ?? and what should i do to reduce the vibrations ihad in mind a piece of foam ??
Old 04-07-2005, 07:10 PM
Fubar-One
Fubar-One's Avatar
Oh, that video was a "Lets see what happens" test. I had taped the camera/tx/battery to a balsa stick then rubberbanded it to the side of the fuse. Stuck up on the end of the stick about 2" above the fuse.
Probably the worst way to do it.
Easiest ways to reduce vibrations:
Mount the camera in something so it is surrounded by foam.
We have also had good luck with it just velcroed to the side of the fuse.
Balance the prop as best as possible.
Run lower RPMs whenever possible.
The best way to mount a video system seems to be to hard mount the camera and soft mount the engine. One of those vibration isolation engine mounts work well.
Since you are using an exisiting plane, your best bets are to either velcro the cam to the fuse, encase the cam in a small balsa or liteply box just big enough to surround the camera in foam and velcro that to the fuse, balance the prop.
Even better, get an electric slowflyer plane such as a Wingo or Slow Stick.
Old 04-07-2005, 08:22 PM
randall1959
With a few exceptions, it's hard to mount a camera in a scale plane so that it doesn't show, but still gives good video. The best thing is to get a plane that camera placement doesn't matter as a means to be anything other than useful. You're not really flying a plane so much as you are a camera One of the better cameras in a scale plane that I've seen is one around here that has a camera inside a large cub. That big cabin really hides the camera and gives a realistic view out the windsheild. I'm thinking about trying my Mustek behind the guns of my Dr1
Old 04-09-2005, 08:27 AM
^^_FaWaZ_^^
kool, anyway im testing it next thursday and ill tell ya how it was...
Old 04-14-2005, 02:40 PM
^^_FaWaZ_^^
hello im back again,
i tried the cam its great no vibration's or anything but the only bad thing was when i get just little far from my position it starts to black out, any ideas on how to make the length longer ??
thanx in advance Fawaz.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
