Help with Black widdow set up
OR
I have the 1000mw transmitter.... 4 wires coming out; video, audio, ground and power. I want to hook up some RCA plugs to make it easy. So I hook up the 12V batt conector to the power and ground. Then I take the outside of the audio RCA and the outside of the video RCA and hook it ip on the same ground with my battery plug and the midle of the audio RCA and the middle of the video RCA and hook them up to the audio and video wires?
Is this right?
Is this right?
IL
RE: Help with Black widdow set up
Yes, the black ground wire is shared to 3 places. The ground of the power, the ground of the audio (outside jacket of RCA cable), and the ground of the video line (outside jacket of the RCA cable for video). The Video wire is yellow coming out of the transmitter, and the audio wire is white coming out of the transmitter. Black is ground, red is power.
Any other questions, just ask. Remember to not apply power to transmitter without an antenna attached. It doesn't like that so much.
Matt
Matt
OR
for a batt I am using a tanic 3 cell 2200. The TX gets REAL hot after about 10 min. Too hot to touch. is this ok?
Also.... can I use the same battery for my airplane and BW TX? The voltage will allways be between 9 and 11V
CO,
I generally don't recommend sharing the battery with the 12v transmitters because there is no way to filter out the noise and voltage fluctuations that will be present as you work your servos and throttle. There isn't much harm in it, but your video results will be disappointing.
Regarding the heat of the tx... yes, these things get really hot. Do try to give it a bit of airflow when it's in the air.
Regards,
Bill
Regards,
Bill
