PAL vs. NTSC for FPV?
ON, CANADA
I would like to get the AVS system sold my rangevideo.com to use in my model aircraft with video goggles. They offer two formats - PAL and NTSC. I have a few questions.
1) What is the difference between PAL and NTSC formats for my purposes? I want the image to be as stable as possible does this mean that I should choose NTSC? Does it depend on what video goggles I buy?
2) Can you suggest a set of decent quality video gogles that I can use with this equipment? (under 400 USD)
Thanks.
Thanks.
RE: PAL vs. NTSC for FPV?
North America is NTSC. PAL is Europe and most of the rest of the world.
I had goggles but switched to a mobile monitor. (5" LCD mounted over the radio) so I am no help there.
FL
PAL seems to be a better standard, but I would NOT use it. PAL is not compatible with anything here in the states, and having equipment that will not work with anything you have or that can be bought here is a BAD idea.
Get NTSC, I use it for all my FPV and it works great. Not worth the hassle to maybe get an imperceptable increase in quality.
JettPilot
JettPilot
HI
As people have said on both this and the other thread stick with the standard that is local to you and your customer base, for you that will be NTSC. You would probably find it hard to tell the difference between them with the quality of the camera headend you are likely to get in those units anyway and you want to avoid confusing matters as much as possible. Plus you would loose quality converting it to NTSC to view at home (if you ever choose to record your flights) and thus loose the small advantages gained by the technology used in the PAL system.
BC, CANADA
doesn't that mess you up when your one eye is "trying" to focus on the flying by video, while the other eye is watching the plane/heli fly from the ground?
