Aerial Photography and Video Discuss the growing field of aerial photography and aerial video right here!
Gyro image stabilization
Old 12-05-2006, 06:30 AM
trireme
Default Gyro image stabilization
Is anybody using gyros to stabilize video?
I am interested in modifying a pan tilt system on a heli with stabilzation.
Thanks-
Old 12-05-2006, 01:47 PM
steve_molmer
steve_molmer's Avatar
Default RE: Gyro image stabilization
trireme:
With a helicopter you need to get rid of as much vibration as possible by balancing your blades and rotating Assembly.
mount the camera pan tilt setup to rubber mounts as is done with gas engines on fix wing aircraft.
You can use a video stabilization software like study hand to get rid of the rest of the bumps.
Gyro stabilization is a real pain and will cost upward of $1,000.00 or more to do it rite.
I would try the cheap stuff first before going on that path.
In the end I think you will find out why a lot of us have gone back to the big fixed wings for video work.
Old 12-05-2006, 06:45 PM
balsabuster2003
balsabuster2003's Avatar
I wonder if an FMA Direct CPD4 co-pilot could be used to stabilize the camera pan/tilt setup? $69.95 + 2 servos.
Old 12-05-2006, 06:55 PM
trireme
I am interested in doing it right. I would like to capture video that need no modification. I notice that companies like coptervision use a globe mount that looks like a fullsize helicopter camera stabilizer, would like to build something to do that. If possible.
Could it be done with two GY401's?
The FMA copilot is to adjust for horizon line, I need a gyro to compensate for major vibrations.
Old 12-15-2006, 03:17 PM
slopedog
Yes, I use a lenlabs KS2 to stabilize the roll axis on my camcopters.
Hard to get electric satabilization that smooth. IMHO
SD
Old 12-15-2006, 05:06 PM
trireme
Where did you get your Kenyon labs KS2? Did you modify it with a 12v to 120v transformer?
