FPV fact sheet
CA
FPV fact sheet
There doesn't seem to be a comprehensive FPV HOWTO which lays out the best equipment and the technique for FPV. It seems to be word of mouth and a lot of bits of information. So far the bits of information converge on the following:
Flight by video with the most expensive equipment is difficult at best.
You can't really fly by video 100% of the time.
The most expensive systems can be flown purely by video, but landings and takeoffs are still by eye.
Cheaper systems allow momentary flight by video with frequent looks at the model to know where it is.
Expect to lose your model occasionally if you fly by video alone and go beyond visual range.
One guy is flying a helicopter by video alone but spent a hell of a lot of money to do it.
Fixed exposure and high resolution isn't required to fly by video. Some fly with only a horizon line to go on and very little detail above or below it.
The difference between wide angle lenses and normal lenses seems hardly noticable. They all lose the horizon.
Personal experience:
The 1mW 2.4Ghz video transmitter interferes with the 75Mhz receiver.
The 75Mhz transmitter interferes with the 2.4Ghz video receiver.
The 2.4Ghz signal can be jammed by security cameras.
You can't tell how high you are from video alone.
With a normal lens, the slightest cyclic input makes the horizon disappear.
Feel free to share any exceptions to these bits.
FL
RE: FPV fact sheet
ORIGINAL: jack crossfire
I fly by video, from taxi out to taxi in, way beyond visual range, and never lost a plane. Its not that expensive, its way less than a full scale plane What is does take is skill, so if you see many failures and limitations, its because the person doing FPV does not have the skill to pull it off. Most people cant even drive worth a schit, even less people can fly with any skill at all [:'(] A picture is worth a thousand words, so a video should be worth a million. Check out my videos with the link below, and then throw that list in the trash.
http://www.youtube.com/profile_videos?user=JetPilott
CA
RE: FPV fact sheet
So if it takes skill to fly a plane by video, it's probably not possible to fly a helicopter by video at all. The one guy who did it, cyber-flyer.com, actually used an autopilot and a ton of navigation telemetry.
MD
RE: FPV fact sheet
MD
RE: FPV fact sheet
BC, CANADA
RE: FPV fact sheet
Hey twinturbostang!
Trying out heli fpv sounds kind of cool though, I have to admit Cyber-flyer and Mr. RC-CAM kind of got it down pretty good. I would like to eventually try it out myself.
I heard some lost hikers got rescued by fpv helicopter.... you got to love it when we reached that time when things like that kind of technology is within our reach now! Anyhow I realize you are a black belt in FPV now since you have the videos to prove it so I'll keep an eye on your post. I could use the knowledge passed on by people who are experienced!
JMS
JMS
MD
RE: FPV fact sheet
LOL Thanks JMS. There's a lot more activity regarding FPV flying over on rcgroups and rc-cam. I think I've seen you over there. If not, definitely check it out.
BC, CANADA
RE: FPV fact sheet
Hey Twinturbostang, yeah I was just checking out the scenery here and yeah, you have seen me around in the rcgroup and my homebase @ rc-cam.
See you around buddy!
FL
RE: FPV fact sheet
[link]http://www.zaneraviation.com/images/FPV Raptor 30.wmv[/link] Please right click and save as. The file is 15mb.
Here is a quote from Hobbyboy at that time about his flying:
The forward flight part is easy. It is the hover where the concentration goes way up. I used a Super Circuits 900 450 MW with a 1/4 wave omni pointed straight down and a full wave 8 dbi omni receiver antenna. The only problem is that at that high of receiver gain the vertical is very narrow (about 30 degrees) so as I depart and arrive I have to slip in low to stay in the reception area. The does not allow for over head flying and even at 1/4 mile away nothing over 1200 feet or so. I have been using the PC67 camera and have been happy with it. I have 3 PC 67's and have one that has been in many hard crashes over two years and still works good. With the above set up you can expect about 1/2 mile solid omni range.
RE: FPV fact sheet
Near the end of the video you can see a yellow pop up tent by the take-off point. That is Bob (Hobbyboy) inside the tent flying by looking at a television set. An extraordinary accomplishment.
That is good!
That is good!
RE: FPV fact sheet
FPV takes practice. I learned on my own,, learned alot of things not to do quickly. Learn to fly your plane first before trying fpv. Get an idea for your thottle positions. Its important to know before you try fpv what your min. throttle position is. This will keep you from stalling. Another great thing is have a spotter near you, until your system
has proven itself. Lots of little bugs and glitches to work out sometimes on these systems. We have to remember that everyone doing this pieces parts and equipment together to accomplish fpv. No company makes a rtf or arf fpv system with airplane. Flying at night is great, but if you loose video link for some crazy reason, its 10X more fatal to your plane than during the day. Its not terribly expensive either. Get good equipment... I am using a 200 mw vid tx and 480 lines ccd camera - 2.4 system on my futaba 9c pcm 6ch with an easy star. I think the plane was only 80 bucks, and they even make them rtf. I disagree that fpv is difficult to fly, and in some cases its much easier. Its a totally different prespective. When your standing on the ground in one place, you are limited and feel limited. When flying fpv its just an awsome experience.
ON, CANADA
RE: FPV fact sheet
I gotta say landings via fpv is much more comfortable than by third person. In fact flying third person is very different than what you expect and more than likely trained on after all these years of video games and flight simulators. I haven't taken off via fpv yet, just seems to be easier to launch then put on googles. I've seen a few videos where the guy started out fpv threw it in the air and didn't realize he stalled the plane till it was too late. Oh yea, your first and second time fpv'ng is more than likely the most difficult and weird, once you get over it then it's cake.
Anyways on to technical... I'm running 900mhz .5 watts with a 2.4ghz radio system. Works fine, wished I had a futaba 9c though on 72mhz, apparently you can get longer range. But I am totally loving the glitch free functionality of the spektrum dx7. Get a diversity controller (which requires two receivers) this will help with drop outs etc. Also look up "goof proof antenna" and make two of those for your two receivers and you should be good to go almost glitch free. Atleast based on the video's I've seen.
Googles are really nice and I would suggest them. Oh and split the receiver and video tx as much as possible to reduce conflicts(one on each wing if possible).... ummmm... carbon fibre and all metals will apparently interfere with both signals. So keep them away from the sensitive stuff. Get good systems(I buy from rangevideo.com) unless you are technically proficient and can add an amp to chineese cheap system but even then for the price difference and pita I would pay a couple bucks more and get a better system.
Ivan.
Ivan.
