Sunpoint, mini-optical-mouse
Good day!
Has anyone purchased from Sunpoint, mini-optical-mouse? They are selling a PILE of the mini cams on ebay. In fact, a quick calculation of $10,000 fines to the number of people buying those, could pay off the national debt or solve world hunger :-) The reviews seem good, but I'm REAL new to the video talk and ebay world. Thanks for any help. The fubar video panning is fantastic, took a little over an hour to download from the dial up, but it was worth it. I'm ready. Spanky |
RE: Sunpoint, mini-optical-mouse
What's the fine for? Selling the same stuff at 1/4 the price of some surveillance sites?
I was joking. one of the forums was talking about illegal activities and fines and such. Hope I didn't strike a nerve.
Tuesday I purchased a 1500mW system BEFORE I found this forum, thats why the question. A friend had a 200mW on a slow stick down in the city and complained about noise. When he would throttle back the picture would clear up. He felt maybe more mW would help. SOOOO I found one on ebay that was 1500mW. But after reading through the forums, I'm not so sure that mW is what lets you go long distances and/or solve the problem w/noise. AND there is talk about quality from place to place. This is why the question about Sunpoint, Mini-optical-mouse. Thanks for reading this far. Spanky |
Gidday Spanky, this may clear up the mw myth for you http://www.blackwidowav.com/questionofthemoment.html I was confused too, until I read this. Regards, John.
That really doesn't sound right. They would normally rate the current draw in ma not mw.
Oh, by the way most new R/C transmitters only put out 1/2 to 3/4 watt or 500-750mw and can transmit for a good 2500 feet. There are many companies selling equipment both on Ebay and off that are falsely stating range. Many companies don't even know what they are selling or what exact frequency they are transmitting on. The best thing to do would be to see if they are FCC approved, if not, buyer beware. I would say that 80% of all spy equipment, home security equipment for sale on the internet is Not FCC approved, including some US venders. I would like to know how much bandwidth all of these transmitters are using. The next local ham meeting is coming up soon, time to hook up with some people with test equipment. If you buy inexpensive equipment look for pll or crystal controlled circuits to avoid drift. The spyderlinker receiver with tuning knob will drift over time but probably not during a flight. |
Well I guess I'm back to where I started again. I thought I learned something but you had to go and burst my bubble, thanks skypilot. John.
Range, Futaba
I agree with john flynn. I realize now how little I know. The proof will be in the pudding.
Skypilot_one you bring up something I'm curious about. Back when my father bought wideband Futaba radio's in late 70's, Futaba advertised 2 mile range documented. They said someone was radioing back what movements for the control surface to keep the plane flying. Does anyone remember? My question is this: is the limited range of 2500 ft you talk about directly because the radio's now are narrowband? I've wondered this in a world that seems to try to focus on cheapening things. Spanky Thanks RCU |
RE: Range, Futaba
I have never flown past 2500 feet. It may be possible but I do not want to try it. We always say if you can see it you can control it which is true for a .60 size plane. I don't think I would want to try it with a 40% Extra though.
I would think that a design that transmits on as narrow a bandwidth as possible would theoretically transmit the farthest, less splatter. 6 mhz for video and sound. I believe many of these less expensive systems transmit over a broad 50 mhz bandwidth or more. Think of it as a water hose and pressure. Put a 1" nozzle on the hose and 50 lb. of pressure (mw), Then put a 1/4" nozzle with the same 50 lb. (mw). Which one will transmit the water or signal farther? The same goes for antennas. A very directional yagi antenna will positively increase range but that would not be practical. All antennas must be properly impedance matched to reduce standing waves or else you don't transmit the power it bounces back to the output and ends up as heat. All of this could be bull, maybe we can have an expert tone in. |
RE: Range, Futaba
I believe many of these less expensive systems transmit over a broad 100khz to 1mhz bandwidth or more. They would normally rate the current draw in mA not mW. ... is the limited range of 2500 ft you talk about directly because the radio's now are narrowband? I've wondered this in a world that seems to try to focus on cheapening things. |
RE: Range, Futaba
Thanks mr.rc-cam-RCU
It is at the limits of this brain for comprehension but it makes sense. I do not think that you will find that decent quality modern 72Mhz R/C Tx's have reduced range. Is there a direct ratio (or sort of) to collapsed antenna feet = Tx distance? THAT would be WAY too easy. Though I'd ask anyway. As you can tell I'm not in a club and no "old timers" to ask. I'll walk back 50 ft and put the Tx behind me also. On a full charge it won't matter, but after a while it will lose the signal if you put it behind your back. This tells me in this primative test there may be a way to determine how far out your plane can go. Whad ya think? Spanky |
RE: Range, Futaba
Is there a direct ratio (or sort of) to collapsed antenna feet = Tx distance? |
RE: Range, Futaba
Looked closely at the frequencies that the cheap systems transmit on and it appears they do fall in the aero nav/ navaid system.
1080, 1120, 1160, 1200. |
No insult intended
Just a thought.
With reguards to the frequencies and the concern for what is right/illegal. Could it be that the technology that we are seeing available to us NOW is only because it is old? The technology dates back to WWII right? (some of it anyway) Please understand I have great respect for our veterans and the like. My hat is off to EVERY veteran. Through the years I've heard my uncle talk on ham stuff how it has become easier and easier until this last time he said anyone can get a ham license. Yes, there are rules, but, there are laws here saying you still can't spit on the sidewalk, or park your horse. I'm 100% sure that there is technology so advanced in NASA and the military that we are not aware of, yet. This is why the cheap stuff from hong kong is coming in and not being shut down. Maybe it's just not worth the taxpayers money to keep on top of it. Especially if it's not going to hurt anything. imho Spanky |
RE: No insult intended
The cheap equipment is broadcasting on Aero navigation channels. I don't know who uses this segement of the rf band to navigate .
I don't know if these units will cause a problem with their relatively low output. |
Would I want to be flying full scale and have a problem because someone is broadcasting ATV, no Point taken. Spanky |
