Predator for AP
Hello I have a Century Predator I want to use for AP and will be lifting about 7-8 pounds between mount and camera equiptment I would like to know if I should change the gearing and What blades I should be running it is stock with a G231 Engine.
Thanks -G [8D] |
RE: Predator for AP
Might want to post the question over at www.runryder.com in the AP forum. Lots of heli experts over there!
Good luck! |
RE: Predator for AP
Hey thanks for the tip I will try that.
-G[8D] |
RE: Predator for AP
RE: Predator for AP
I am using a preditor in my ap business and im running stock gears and it has no problem lifting my 9 lbs pod you can go to www.wildsidevideoproductions.com and check it out theres a video on there you can look at.
RE: Predator for AP
I have a G26 running a on a stretched Predator running 830MM blades but 810's are plenty for 8-9 lbs.
RR [:'(] |
