Preasure Sensor for wing
Hi
The basic principal of airplane flying is there is more pressure on the bottom of the wing than on top. Hence I was wondering does any one know of digital pressure sensor that I could place on the bottom and/or top of wing in my home made plane models to check pressure.
Thank you
kingofjong
Thank you
kingofjong
Better to simulate it!
Hi
Thank you
kingofjong
Thank you
kingofjong
There are some prssure scanners available bear in mind that those equipments may be much more expensive than your whole aircraft and tricky to use, if you are flights are in low reynolds number and low angle of attack, you should better simulate it using XFLR5 or one of CFD softwares.
Hope that helps,
Have fun!
