Go Back  RCU Forums > RC Airplanes > Aerodynamics
 ZERO LIFT ANGLE >
ZERO LIFT ANGLE
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
ZERO LIFT ANGLE
Old 06-07-2004 | 03:04 PM
HO-229's Avatar
Default ZERO LIFT ANGLE
How do you determine the zero lift angle using "PROFILI"
Old 06-07-2004 | 04:14 PM
Default RE: ZERO LIFT ANGLE
On Profili, click on the toolbar button for the polars, marked with a "P". Select your airfoil and the other settings and click draw. It will draw the CL vs CD polar. Then, a 2nd row of buttons appears at the toolbar. One says CL(alpha), CD(alpha). Click that and it will draw the lift and drag curves. Where the lift curve crosses the axis is the zero lift angle. See the pic:
Old 06-08-2004 | 07:20 AM
HO-229's Avatar
John,
Thanks for the information.
What chart plots the airfoil moment & how do you get to it using "PROFILI"
HO-229
Old 07-02-2004 | 01:10 AM
Schpankme's Avatar
Try the 50/50 rule (see Example).
For those comparing my accuracy - RONCZ R1145MS AIRFOIL
_________
Schpankme
"Always remember you’re unique, just like everyone else."
