Go Back  RCU Forums > RC Airplanes > Aerodynamics
Math problem calculating Wing Length to wing area!! >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 07-14-2002 | 08:04 PM
rustyrivet's Avatar
Default Math problem calculating Wing Length to wing area!!
I want to blow up the plans of a 71" long, 824 square inch wing by 25%. Does this mean then that to figure out the wing area of my new larger 88.75"sized wing I simply multiply 824 Sq. inch x .25 = 206 sq. inch, 824 + 206= 1030 sq. inches???
The dilemma and suspicion I have about this math, is that when I've seen every company (like Top Flite for example) increase their 63" wingspan P-47 or F4U model to a giant 85" wingspan version of the same model, the wing almost doubles in wing area instead of proportionatly increasing 25% -30%!! Blowing up my plane 25%using these Top Flite models as an example, would likely turn my plane with a wing of 824 sq. inches, closer to a wing area of 1300 or 1500 sq inches. ( instead of the 1030sq inches I come up with mathematically.)
So then the question is: What would a 71" wing presently at 824 square inches, work out to in square inches if I increase the length 25% to 88.75"long. Evidently the math formula may not be as simple as I expected.
Old 07-14-2002 | 08:25 PM
WS
You will need to muliply your area by 1.25^2, since both chord and span are increasing and area is chord * span. So, multiply your area by 1.5625.
Old 07-14-2002 | 08:27 PM
Hi,
"I want to blow up the plans of a 71" long, 824 square inch wing by 25%. Does this mean then that to figure out the wing area of my new larger 88.75"sized wing I simply multiply 824 Sq. inch x .25 = 206 sq. inch, 824 + 206= 1030 sq. inches??? "
I suggest enlarging the plans vs blowing them up
Wing area is span times cord. I assume you are going to increase the cord by 25% so here is the math.
71" *11.6" = 824 sq "
88.75" * 14.5" = 1286 sq"
Hope this helps,
Dave
Old 07-15-2002 | 06:02 AM
Mike James's Avatar
Default Methods
I agree...
Blowing up your plans can start a fire, whereas enlarging them simply makes them bigger.
Sometimes though, after making a plane from plans, I've considered blowing up the plane.
Old 07-15-2002 | 10:15 AM
I fill dumb, what is the difference between blowing up and enlarging. I use either word when I am making something larger then the original. Please enlighten me, as I want to blow up/enlarge my Sig SE plans to make a 80" one.
Old 07-15-2002 | 07:15 PM
Default No Difference
Main Entry: blow up
Date: 1536
transitive senses
1 : to build up or tout to an unreasonable extent <advertisers blowing up their products>
2 : to rend apart, shatter, or destroy by explosion
3 : to fill up with a gas (as air) <blow up a balloon>
4 : to make a photographic enlargement of
5 : to bring into existence by blowing of wind <it may blow up a storm>
Those guys are just being funny
Oh yeah, Dave nailed it on the head.
Cheers.
James
Old 07-16-2002 | 01:29 AM
Mike James's Avatar
Default Humor - No offense intended
toyking23,
We're just kidding around a bit here. Both phrases are fine.
Quoting Hannibal Lecter:
"Oh Clarice, you really must get more fun out of life."
Have fun!
Old 07-16-2002 | 02:57 AM
rustyrivet's Avatar
Default Calculating the wing area.
Wells and Dave,
Thanks for the help. It was a relief to crunch the numbers properly to come up with a plane at something like 32.5 oz. per square foot wing loading, instead of the 40.5 oz. I was getting using my own "math made easy" method.
As for you other guys; I'm glad I didn't ask you how to "multiply" something. I'd be getting a two day course in sex education.
-Randall
OK, a little silly humor never hurt anybody
Old 07-16-2002 | 03:01 AM
My Feedback: (31)
Try this one for obtaining a desired wing area.
824 known area / desired area 1286
1286 divided by 824 provides a ratio = 1.56
square 1.56 and you have a ratio that can be used on a copy machine of 125% which will net you 1286 sq.ins. @ 88.75 wing span.
Similar math while looking for a specific wing area!
An 80" SIG SE would be figured like so:
desired WS = 80" divided by known WS 51.5' = 1.554
known Wing Area = 614sq.ins.
614 divided by 51.5 = 11.92 chord
11.92 x 1.554 = 18.5 chord
80 x 18.5 = 1480sq.ins.
Use a ratio of 1.55% on the copy machine.
