Go Back  RCU Forums > RC Airplanes > Aerodynamics
Reload this Page >
Trailing Edges on Large Scale Aerobatic Planes
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 02-28-2002, 02:47 AM
Don Szczur
Don Szczur's Avatar
Default Trailing Edges on Large Scale Aerobatic Planes
What are the thoughts and exeriences of razor sharp vs thick trailing edges on large scale aerobatic planes, about 40%
Carden has pretty thick trailing edges.
Fiber Classics has very thin (like sailplane) trailing edges.
Both have been very competitive in IMAC, Masters, and TOC events.
Which works better and why or why not?
Don
Old 02-28-2002, 03:24 PM
can773
can773's Avatar
Don
Cant speak on GS, but when I was in Ireland this summer I was shocked to see the size of the TE on CPLR's, and actually a lot of the European guys (as well as Japanese) planes. The rudder TE must have been 1/4" thick, possibly more (I forgot my ruler, but I will have it in Poland!!!!). Dont know yet if it is better or not, but on my Evolis's I plan to run thick TE to see if it is better than the thinner ones I have used in the past.
Old 02-28-2002, 06:37 PM
Ollie
A 1/4 inch thick trailing edge 12 inches long has a frontal area of 3 square inches and about the same drag as a three square inch plate perpendicular to the air stream. Drag is an advantage for pattern competition in that it limits acceleration and makes it easier to fly a pattern that appears to have a constant speed. Other than looks and style, I can't imagine why pattern competition planes aren't equipped with more parasitic drag producing features. Why spinners and cowlings? Why not draggier landing gear, struts and open cockpits?
Rounded trailing edges produce vortex sheading that can power flutter. Blunt trailing edges may do the same but the energy may not be high enough to cause problems with a slow pattern and stiff linkages. The weight of a blunt trailing edge versus a sharp, gradually tapered trailing edge will reduce the flutter speed somewhat.
Old 02-28-2002, 09:14 PM
can773
can773's Avatar
Please explain?? How can a TE have the same effect as a flat plate perpendicular to the flow?? I can understand there will be drag due to the airflow becoming turbulent after leaving the wing, but as much as a flat plate?? Be as technical as you want, I have a degree in mech eng and would like to understand the reasoning behind this My experience is in flow thorugh pipes and nozzles, not a lot in aerodynamics.
Old 02-28-2002, 11:35 PM
Ollie
Chad, you were right to question my statement about thick trailing edge drag. It is at least an order of magnitude less than a flat plate of the same area. I was wrong and I apologise for such a gross error.
Old 03-01-2002, 02:45 AM
can773
can773's Avatar
Whew, I was starting to think that if it was true my plane would never come down from the sky Thanks!
Old 03-02-2002, 05:18 AM
Don Szczur
Don Szczur's Avatar
These data points are extremely useful. Thank you very much. Chad, from the ones you saw, do you recall if the other control surfaces were also thick at the trailing edge?
Thanks much,
Don
Old 03-05-2002, 07:11 PM
can773
can773's Avatar
Thanks much,
Don
Hi Don
Yes the elevators and ailerons were also thick, but not as thick as the rudder was. They were over the 1/8" "standard" maybe up around 3/16", but not quite 1/4". I will look through my pictures at home and see if I have one that shows a little.
Old 03-10-2002, 05:11 PM
rcman-RCU
My Feedback: (31)
There was a post on this subject quite a while back relating to trailing edges on full scale aerobatic planes. As I recall, many of the full scales had control surfaces made out of welded tubing with rounded trailing edges maybe 1 to 2 inches thick. This would equate to .250 to .500 inches thick for a quater scale model. The thought was that if the full scale guys don't worry about trailing edges, maybe it is not too important for us modelers either.
It does seem to be well confirmed that rounded trailing eges are more prone to flutter than sqaured off edges. Also, heavy trailing edges are more prone to flutter than light ones. I think that stiff control surface designs and slop free control linkages are a lot more important than trailing edge shape.
On racing or high speed planes, a sharp trailing edge would result in a meaningful reduction in drag.
Old 03-13-2002, 01:41 AM
Don Szczur
Don Szczur's Avatar
Not sure if I've seen many with 1 or 2 inch trailing edges- the Caps and Sukhois that I've seen were about quarter to half inch but the molecules are at a different scale there.
So far what I've heard is that its advisable to put angle stock on the TE to bring up the TE thickness. This makes the control surface more stable as well as less sensitive to minor inputs. Also having this kind of material on the rudder provides damping stability in the (yaw).
Thansks all for the input,
Chad, You are a lot closer to making it Poland than I am- I'm jealous!
Don
Old 03-13-2002, 03:29 AM
gubbs3
I feel the opposite. In my opinion, the bulky trailing edges may inhibit flutter at high speeds. My reason for this assumption is my knowledge of r/c boats. My unlce has a racing hydro that is capable of 70+ mph. This boats rudder is knife edged at the leading edge but 1/4" thick at the rear. As asked some guys about this, since it seems like it would produce more drag, but they said it keeps the rudder from fluttering since it creates an air pocket behind the rudder. It seems like a sound enough reason.
Old 03-14-2002, 12:21 AM
can773
can773's Avatar
Don
Hi Don
Benefit of being in Canada We dont much quite the number of competitors that you guys get down there. Sometimes I wish we had that level of competition up here, I am coming down to Muncie this year with some buds to get a little head start for Poland, probably catch up with you then!!!
Old 03-26-2002, 05:31 AM
niccolai_m
I would have thought at the reynolds numbers being operated at the trailing edge would have little effect on drag and that the flow at the trailing edge is problably pretty low energy, possibly close to detaching in some situation, if not detached.
So a thick trailing edge may have some other reason for being superior. Perhaps it leads to a stiffer component. This would improve roll effectiveness and may give an edge during tail slides.
Old 03-31-2002, 12:16 PM
rmh
rmh's Avatar
Thick trailing edge allows for POSSIBLE increased structural rigidity.
BUT also increases potential for control surface having it's c/g further aft - bad news!
Full scale design has zero -or less relationship with our stuff simply because of size difference -
The trick setup on full scale -with the blunt TE gives better air attachment to control /flying surface -by creating low pressure at TE.
Best bet for model?
The stiffest -lightest control surface possible with it's CG being quite close to it's LE.
I use single ,individual, digital aileron servos on models with 1800 sq in wings - I lighten and balance all surfaces. No sealing tape hinge lines - just reasonably tight fitting.
Having tried a bunch of aileron types on larger models - barndoor - on Dalotels- full span 2-1 taper ratio on Staudachers- 10-1 aspect ratio on rectangular ailerons for CAPS- etc.,
The only common link I keep is to keep em stif and and lite and reasonably balanced (forward CG).
They all perform well with no flutter -
As far as any improvement in how the "thick vs thin TE" part of the whole equasion works--
I can't find any relationship.
On bigger stuff - It makes sense tho-
Old 04-03-2002, 02:52 AM
Daniel Z
Daniel Z's Avatar
Location: SantiagoReg Metropolitana, Providencia, CHILE
Im in pylon racing, and in this statment we all try to get sharp an stiff TE to reduce drag (turbulent flow behind the airfoils) and avoid flutter; in fact some people finish the TE with glass cloth to get optimal results (like a knife!) and almost all QM40 are composite made to help this. Maybe in aerobatics as the others said for the control throws and forces involved in freestyle flying the drag and the structural reinforcement may be usefull, but I think that there are other ways to increase drag more eficiently... just a couple of thoughts...
Greetings
