Balancing a canard or tandem wing biplane for initial flight.
My Feedback: (30)
When we balance the conventional airplane for its initial flight, we often bias the balance toward nose heavy for the initial flight. This way, the elevator is not too sensitive while we work out the kinks.
But, what about the planes where the elevator in on the front wing?
Should I bias the plane slightly tail heavy for the first flight? This would take some authority from the elevator which is in front.
Confused as usual
Elson
Confused as usual
Elson
ORIGINAL: rc bugman
Confused as usual
Elson
Confused as usual
Elson
Same procedure.
CG should be forward the center of lift created by the two wings or the stab and wing.
If there is fuel tank and it is located aft the CG, it should be full as normal for proper balance (worst tail heavy condition in real flight).
My personal preference is level fuse rather than nose slightly down.
NB, CANADA
For forgiving handling, a canard should be balanced slightly nose-heavy by about the same amount as would be indicated for a conventional tractor layout. A good way to check this is to make up a profile fuselage small cardboard hand-launched glider with the same relative wing and stab areas and tail moment arm, and test for stable glide with various CG locations, courtesy of paper clip nose weights. A six inch wingspan is adequate for the little glider, and flat-plate non-cambered airfoils are fine, as far as CG is concerned. This little trick should get you within a couple of percent of wing chord of the best CG location, although test flying of the full-size version may indicate that some fine tuning of CG is needed. Always start a bit on the nose-heavy side.
I fly a Canard all of the time. Search for the Canard CG calculator and go by that. DO NOT MAKE IT TAIL HEAVY.
You mean this one?
http://adamone.rchomepage.com/cg_canard.htm
the canard CG locator application......................... Look familiar?
My Feedback: (30)
Thanks for the replies. Somehow the responses are not logical. Here is why.
With conventional aircraft (wing in front, elevator in rear), a tail-heavy airplane puts too much authority on the elevator which makes the elevator too sensitive and the plane becomes difficult to impossible to control. Move the weight forward, the elevator loses sensitivity and the plane becomes better "behaved". Move the weight too far forward, and the elevator becomes insensitive and the plane becomes difficult to fly.
With a canard, the plane is backward with the wing in the rear and the elevator in front. Logic would suggest that too much nose weight would make a canard difficult to control like a tail heavy conventional plane. Elevator would have too much authority. Move the weight back and the fore mounted elevator would lose authority.
A tandem-wing biplane is yet another beast. Two equal sized wings located on either end of a fuse seems to be naturally stable where ever the CG is located between the wings.
Elson
Elson
According to that logic, a tailless aircraft couldn’t be either nose heavy or tail heavy.
However, pitch stability is not determined by the location of the stab respect to the main wing.
The more or less authority of the stab, wherever it is, comes from how much the airstream helps it or not to stabilize the main wing.
In conventional, layouts the stab works against the lift produced by the wing.
In canard layouts, the stab helps the main wing to lift the aircraft, and then a smaller wing is possible.
This website has animated pictures with very clear explanations.
http://www.geistware.com/rcmodeling/...rorgravity.htm
Just click on the tabs under each picture to activate the animation.
MN
ORIGINAL: rc bugman
With conventional aircraft (wing in front, elevator in rear), a tail-heavy airplane puts too much authority on the elevator which makes the elevator too sensitive and the plane becomes difficult to impossible to control. Move the weight forward, the elevator loses sensitivity and the plane becomes better ''behaved''. Move the weight too far forward, and the elevator becomes insensitive and the plane becomes difficult to fly.
Elson
Elson
I think part of what is confusing your logic is the names that we give to various control surfaces. Control surface names have no bearing on aerodynamic stability. We just call these different control surfaces different names out of convention more than anything else. For example, flaps on a conventional design can have the same function as the elevator on a canard: flaps go down-nose pitches up: elevator goes down on a canard-nose pitches up. You could even fly a conventional design with just flaps for pitch control without any movable elevator on the horizontal stab at all. It's the same with a canard configuration, no movable elevator on the horizontal stab. is needed. Pitch control can be had with elevons on the larger, aft wing only. We just tend to put pitch control surfaces on the wings furthest away from the C.G. for leverage reasons.
MN
ORIGINAL: CowboyLifesaver
I'd call Scaled Composites and get the word from the horses mouth myself.
ORIGINAL: rc bugman
Elson
Elson
Here is exactly what will happen if you fly a tail heavy canard...
The nose will come up before the main wing is flying the wing will stall and snap roll into the ground.
here are some things to look at:
http://www.desktopaero.com/appliedae...stability.html
http://yarchive.net/air/canard.html
http://www.mh-aerotools.de/company/paper_3/yaka.html
"Logic is a wreath of pretty flowers, that smell bad!"
— Mr. Spock
A good book to read:
ORIGINAL: Craig-RCU
What word?
My Feedback: (30)
Thanks for all of the input. It appears that it is time to build a canard and play with the CG. That is the problem being a scientist by profession. You have to hit your own fingers with a hammer to believe it hurts.
I don't dis-believe your explanations but somehow I am missing the logic.
Thanks again
Elson
Thanks again
Elson
Here is a little experiment, build a flat panel canard glider in the proportions you intend to use out of balsa or even cardboard weight it for the proper cg location.
Toss it and see how it flies, then set it up tail heavy and try it again, quick and easy, you will see what happens.
ORIGINAL: rc bugman
Feathers in an arrow create an artificial drag that is necessary in order to achieve a stable flight.
The CG (located by the middle point of the arrow) is forward of the center of drag, or vice-versa.
Then, the airstream will keep that center of drag directly behind the CG (around which the arrow rotates for any disturbance).
If the arrow starts flight with the feathers pointing forward (case similar to a tail heavy airplane, for which the CG is aft the center of drag or aerodynamic center or neutral point), the airstream will force the arrow to rotate around the CG by dragging that point of resistance or center of drag, and placing it directly behind the CG, as it should be.
In other words, a tail heavy airplane (regardless the type or configuration), will be forced by the air stream to fly tail first, with disastrous consequences.
I tried scratch building a 30 inch span canard for .049 power some years ago. The internet was full of hearsay and mumbo-jumbo, but no definitive CG calculators that I could find. The usual advice was to "build a chuck glider".
I found that in order for the canard to function smoothly and effectively, it needed to have a "stoopid lookin' amount" of foreplane area, no matter where I put the CG. With a "stylishly proportioned" foreplane [as in smaller] the model behaved like it had a toggle switch for pitch control.
It flew level just fine.
I ended up cutting the foreplanes off and flying it with elevons.
MN
ORIGINAL: iron eagel
Burt Rutan designed many canards, he should be able to explain the aerodynamics...
ORIGINAL: Craig-RCU
What word?
I think your post #10 was fine.
I just wasn't sure if you knew who was involved with SC, when you asked what word, that is all...
They, as I, would agree with what you had said.
MN
ORIGINAL: rc bugman
Thanks again
Elson
Thanks again
Elson
Your logic lead to the contradictory result that moving The C.G. toward the nose of a canard would cause it to behave as if it were tail heavy. The error in your logic is of thinking that the specific case of conventional designs applies to all cases of various airplane designs. This is an error of inductive reasoning. An example of the error is this argument. Bill is tall. Bill is a person, therefore all people are tall. Your reasoning follows that same form. In the same way it does not follow that because Bill is a tall person that all people are tall, it does not follow that moving the C.G. toward the elevator on a conventional design has the same effect on all designs. Any clearer for you?
MN
