Super Soprtster Elevator question ?????
I have a Super Sportster I bought from my brother in law and love it, I just have one question. Last night while flying the plane I started to notice that when I was flying fast and input a lot of elevator the plane would not only pull up but also start rolling to the left like I was adding aileron. This seams only to happen when going fast and using a lot of up elevator. I have a few ideas, first I thought maybe I was not pulling straight back on the stick. I checked that out and I am sure that is not it. I did not check and see if one side of the elevator was loose which I guess could be the cause but will have to wait until tonight to check that out. If anyone out there has another idea I would be glad to hear them.
Good luck with it!
That fixed the problem.
Sounds to me like accelerated stall. Many planes do this when yanking hard causing high G loads. This increases the stall speed and due to torque, p-factor, angled thrust, it doesn't stall straight ahead, but it falls off to one side.
Thanks. This seems to be the most likely cause as it only happened when I was at high speed, and the elevator is solid. My brother-in-law never noticed it when he flew the plane, but I have been really ripping it around. The last time it happened I was coming out of a diving spin and I almost lost the plane. I was lucky and recovered and was able to land. I guess I will just have to watch my speed at low altitude more. Thanks again.
Matt
Matt
One thing you should do is to practice the accleerated spin so you can anticipate the outcome. Get yourself to a safe altitude in straight and level flignt. Pull back on the elevator firmly and see what happenes. It should "roll or spin out of the climb the same way each time. You will get a feel for when it will happen. So just do them on purpose a bunch of time and practice the recovery and it will be second nature to recover when it happens on accident. Then, once again at a safe altitude, do the same thing while leveling out from a downline. These are the ones that will really hurt you if you are not expecting it. All in all you are just becoming more familair with the characteristics of your plane and this will make you a better pilot.
Good luck with it. I have really injoyed the sportsers I've owned in the past.
Well ithappened again last night and I was not going that fast. May be half speed. I was very high when it happened. I had just taken off and climbed high then pulled up harder and the plane started spinning to the left. When I landed checked out the plane again and noticed I have a slight warp in the left aileron. I am thinking may be the warp is enough to cause this. It is worse at the tip and if I remember right the further out on the wing the more it affects the flight. I will be trying to straighten it out and see how that works out.
...You either have loose hinges or the torque rod between the elevator halves is loose in the balsa. Also, check if the elevator halves are lined up evenly. The rod may have twisted. Whenever I build a model with separate elevators, I try to run two servos, one to each half. IMO, the torque rod is a problem waiting to happen.
Good luck with it!
Okay it is not the interconnector I have checked and it is tight. The only thing I see that might be causing it is the right aileron, which is more pronounced at the wing tip. I am going to work on that and fly it again this week end if the weather permits. The last flight I was flying slower and the plane still kind of rolled hard to the left when I pulled up hard at altitude. I will let you know how it goes this weekend if I get to fly.
