Engine when enlarging plans
1 Attachment(s)
My winter project will be a 1/4-scale Fairchild 24W, enlarged from 1/4,8 scale plans. (from 90" to 108" span)
The original plans was designed for a 1 cu.in. four stroke engine What would theoretically the (four stroke) engine size be for the 1/4-scale model, in order to get the corresponding performance? I assume there is a formula Thank in advance, /Leo |
A 1.20 4-stroke.... you can always pull back on the power. :)
I think if you double the size of the plane, you should put an engine four times bigger.
Re: Engine when enlarging plans
Originally posted by Leo My winter project will be a 1/4-scale Fairchild 24W, enlarged from 1/4,8 scale plans. (from 90" to 108" span) The original plans was designed for a 1 cu.in. four stroke engine What would theoretically the (four stroke) engine size be for the 1/4-scale model, in order to get the corresponding performance? I assume there is a formula Thank in advance, /Leo I take it for granted that you use the radial cowl. As for engine, a 1.50 or 1.80 Saito, or 1.55 Enya FS would be ideal. Hej då! |
I already have a good set of plans, drawn by the English designer Phillip Kent.
Thanks for the suggestions though I think I will install my Laser 200 twin. Yes, I can always pull back on the power Thanks 3D Joy for the formula Tack och hej Shonny :D /Leo |
| All times are GMT -8. The time now is 08:30 AM. |
