Left roll and right roll not the same.
When I do an aileron roll to the right, the roll is very axial but when I aileron roll to the left it is sort of a cork screw. Why is that and what is the fix?
Thanks. |
My guess is that you have unequal aileron throw from side to side. What I do is break down the ailerons into 4 quadrants. Up and down, right and left. Then I go into the ATV for the aileron and the aileron 2 and adjust the ATV of both channels until I get exactly the same deflection in all 4 quadrants. After that I throw in about 4-5% differential.
Thanks for the reply speedracer. I will check the throws on each side and try to get them equal.
Mike |
Originally Posted by Indiomike
(Post 11969878)
Thanks. Another issue that can happen is that the roll rate will differ right from left. The fix in this situation is a small increase in deflection on the slow side. BTW- a contra rotating propeller(s) cures these issues. A contra does not cure motor torque tho, unless each prop is driven by its own motor which in turn rotates in opposite directions |
Thanks Matt. I'm pretty careful to set up each wing servo so that the angle between the horn and pushrod is at 90 degrees. I assumed this would give equal throw to the ailerons. I will experiment adding a bit of differential and using some up/down elevator on the cork screw side to see what effect it has. Not all, but some of my planes has an axial roll one direction and somewhat corkscrew the other direction. I was curious as to why that was happening.
Mike |
Mike, please do check the ailerons. What I have seen is that most guys setting up dual servo aileron setups will adjust ATVs at the same percentages with the same length servo arms and control horns expecting it to result in equal throws. Seldom does that work out. Most guys never realize the loss of performance. Taking the time to balance all the throws and adding the correct amount of differential will help. That being said getting an airplane to roll exactly the same both directions is probably not going to happen. I know for a fact that I roll better to the right then to the left. This is because right is my dominate roll direction even though I do a fair amount of pylon racing and my dominate turn direction is left. Once the airplane is set up well it becomes a matter of practice.
I think you are correct speedracer. I assumed with the ATV's the same, 90 degree control arm to servo orientation, the ailerons would mirror each other. Apparently that is not always true. I will do some differential adjustments and see if I can minimize the corkscrew side even though it isn't horrible. I just hoped the plane would roll either direction the same way. Probably a little more practice on my part would improve the situation considerably.
Mike |
Your rudder could be trimmed to favor one side.
You might not notice it in normal flight. If you are accustomed to flying with both thumbs, you will find yourself correcting more on one side in low speed turns. Spiral slipstream could also be a factor if there is not much fin/rudder area below the elevator (such as elev/stab mounted on the bottom of the fuselage). Right thrust if there is any, will tend to negate the spiral slipstream. Uneven lift (up on one side more than the down on the other side) is the most likely cause. Flat bottom wings will need more up aileron on one side to equal the down aileron plus wing camber on the other side. (Another reason to use differential besides adverse yaw.) Mostly this will make it corkscrew both directions, but if one wing is twisted or the aileron linkage is off center such as from trimming to compensate for the off center rudder, the corkscrew will be more pronounced on one side. Finally, exhaust blowing over the wing on one side can increase the lift of that wing more than the other side. It is not much, but will add to any other causes. |
To piggyback on what Jennifer Curtis said, with all of the non-symmetrical forces present, maybe non-symmetrical aileron throw is a good thing.
Kurt |
G'day Mike,
Are you a mode 2 flier? Sometimes it's very difficult to make a 'pure' aileron input without putting in a small elevator input as well, and it's different left and right. It's because of the way your thumb sweeps left and right. The elevator input can give you the cork screw roll that you are seeing. Might not be the issue but something to think about if you can't find any other issues with your ailerons. Dave H |
Originally Posted by gerryndennis
(Post 11976917)
G'day Mike,
Are you a mode 2 flier? Sometimes it's very difficult to make a 'pure' aileron input without putting in a small elevator input as well, and it's different left and right. It's because of the way your thumb sweeps left and right. The elevator input can give you the cork screw roll that you are seeing. Might not be the issue but something to think about if you can't find any other issues with your ailerons. Dave H All of the comments were appreciated everyone. Thanks Indiomike |
| All times are GMT -8. The time now is 11:59 AM. |
