How much right thrust/ when to add right thrust/ rules of thumb?
When do you add right thrust? Does it depend on prop size and rpm? How much right thrust? There must be some sort of relationship between prop size, rpm, and deg of offset.
Thanks, --Rick |
All the planes I have ever built have required some right thrust and some downthrust, the amount varied widely. It seems that high wing planes and bipes require more right and down than low wingers do. The amount is best determined by experimenting. when you set up your motor mount, leave provisions for adjusting thrust line by adding washers or spacers at the appropriate places. A good starting point seems to be about 3 degrees right and, on high wingers, 5 degrees down.
| All times are GMT -8. The time now is 11:49 PM. |
