katana
1 Attachment(s)
i am building a 80 inch span katana and i am having a bit of trouble with the aerofoil any help on aerofoils Books,websites would be much appreciated.
As i am building it from scratch all the info i have are pics of the plane and specs ROOT AIRFOIL 10-12% Symmetrical TIP AIRFOIL 13% Symmetrical WING SPAN 2019mm ( 79.48IN) Thanks :D |
RE: katana
Nice project Sibot!
Wich motor are you going to put on it? I am interrested by this plane but, all available kits are ARF and as a builder, i would prefer builder mine from a plan or a kit. In the meantime, here are few Katana's links: http://www.mcmodelline.com/MCK251E.htm http://www.giantscaleplanes.com/Katana_80.htm http://www.aero-works.net/store/detail.aspx?ID=80 Daniel |
RE: katana
Other info. Hope it helps!
The full-size Katana is a single seat display and competition aerobatic aircraft manufactured in Milan by Pietro Terzi Ltd. It is an all metal aircraft with composite undercarriage, powered by a Lycoming IO-720 engine driving a four blade constant speed wooden propeller. It is stressed to +/- 12 G with a roll rate of 400 deg/s., a maximum level speed of 360 km/h (220 Mph) and a stall speed of 98 km/h (60 Mph). http://www.moki.co.uk/terzi.htm http://www.pietroterzi.com/skkt.htm http://www.rcuniverse.com/forum/m_15...tm.htm#1505411 Daniel |
RE: katana
1 Attachment(s)
Found a web site with this Katana 3-view a while ago. I´m not sure if it is true to scale
though. The wing looks really thick. I could e-mail this 3-view as a 40 kbyte hi.res. ps file if you like. When opening it in Photoshop, the image will be around 6500X2000 pixels or 91X30 inches /Leo |
RE: katana
1 Attachment(s)
Trying again..
RE: katana
http://www.aae.uiuc.edu/m-selig/ads/coord_database.html
this site over 1500 airfoils. hopefully this will help |
| All times are GMT -8. The time now is 12:17 AM. |
