RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Powered Parachute R/C (https://www.rcuniverse.com/forum/aerodynamics-76/18660-powered-parachute-r-c.html)
Lucke 06-24-2003 08:39 AM
Helo I´m New for here and like to do some questions:
I will to construct a Powered Parachute,
I will use a Foil (canopy) used to pratice Kitesurf (this foil is semi -eliptical and has 1,6 square meters).
The trike has 2,5 kg of weight and the engine is a O.S .46LA Blue wich he propeller 11"x6" pusher.
This is enough to fly ?
What I have that to take in consideration my model to fly?
Exist calculations that I have that to make?
Many thanks for help-me,
Lucas
Lightfoot 06-24-2003 10:58 AM
I think you have a pretty good match between the size of the parafoil and the engine but the weight should probably be in the 1,5 to 2 kg range.
Lucke 06-24-2003 11:56 AM
Thanks Howard, [img]i/expressions/face-icon-small-smile.gif[/img]
I was thinking about a less weight ...
Lucke. [img]i/expressions/face-icon-small-smile.gif[/img]
