RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Deviation from thrust line (https://www.rcuniverse.com/forum/aerodynamics-76/203686-deviation-thrust-line.html)
Volfy 07-22-2002 05:36 AM
If I mount the engine such that the thrust line deviates from that which is drawn on the plan, what corrections, if any, should I make to compensate?
Obviously I would need to adjust the fuel tank position to center with the carb. But would I have to adjust the downthrust also? Say, for example, a low-wing airplane which calls for 2 degrees down thrust. If I move the thrust line farther up, would I need to decrease or increase the down thrust angle?
How about incidence angles, any changes necessary there?
