RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Where to put CG? (https://www.rcuniverse.com/forum/aerodynamics-76/2114211-where-put-cg.html)
KW_Counter 08-24-2004 02:45 PM
Where to put CG?
Hi,
If you could put your CG anywhere you wanted on a fuse where would you put it? Why?
KW_Counter
Tall Paul 08-24-2004 04:47 PM
RE: Where to put CG?
I've noticed that the c.g.s on my fuselages tend to come out just aft of the trailing edge of the wing.
Johng 08-24-2004 07:05 PM
I tend to favor a static margin of about 2-5% [sm=devious.gif]
rmh 08-24-2004 08:50 PM
Use a better grade of tape -
I put my CG's on with 3M and they stay in place ---
feihu-RCU 08-24-2004 10:40 PM
I don't put it anywhere I want; I mark where it should be for convenience.
I balance my airplanes at 30% mac with the wing on, and then remove the wing. I then see where the fuselage is balanced and then mark that place.
Why? So I can check the fuselage CG in the event some of the internal components get moved around, or a fuselage mod was made, or I need to deviate from the 30%mac.
