RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Bipe Balance?? (https://www.rcuniverse.com/forum/aerodynamics-76/2552280-bipe-balance.html)
Canardman 01-17-2005 08:57 PM
Bipe Balance??
1 Attachment(s)
I got my first biplane this weekend, and flew it Sunday. I have never flown anything so hard. I set the cg about 20% of the bottom wing. It acts like the CG is off. oes anyone have advice on where a biplane CG is??
-Thanks-
Tall Paul 01-17-2005 10:28 PM
RE: Bipe Balance??
If that's a Waco, the upper wing is swept, correct?
The c.g. should be at 25-30% of the mac, wherever that falls on the plan view.
I suspect it's forward of where you have it.
Post a plan view..
LesUyeda 01-18-2005 12:57 PM
RE: Bipe Balance??
1 Attachment(s)
This has always worked for me.
Les
Canardman 01-18-2005 01:31 PM
RE: Bipe Balance??
I don't have the plans. It looks like it may be a bit tail heavy. The top wing is swept back. Looking at the drawing, my CG is way too far back. that would explain the way the plane acts.
-thanks-
LesUyeda 01-19-2005 10:42 AM
RE: Bipe Balance??
Use caution when using this scheme. With a sweptback wing, MAC is not where it would appear to be from this. MAC for the top wing will have to be calculated, then the drawing applied.
Les
