Smoke System and Wing Loading
Have a TME smoke system and was thinking about putting it into my Sig LT-40. Engine is an OS 40 LA with 10x6 apc. Have a design for preheating and it should work, according to TME directions.
Was going to go with a 4 oz smoke tank and enough batteries for a few smoke flights. Was also thinking about mounting the assembly under the aircraft in a removable tray. Will this add too much wing loading or not? Any comments will be appreciated. |
RE: Smoke System and Wing Loading
That plane is pretty light and big. I don't think it will be a problem.
I strap a digital camera set-up to my LA 40 powered Avistar and it handles it just fine. |
A little extra weight on a LT-40 isn't going to hurt it any. However, you may have a tough time getting decent smoke out of a .40 two stroke. Good luck.
| All times are GMT -8. The time now is 03:58 AM. |
