RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   change model (https://www.rcuniverse.com/forum/aerodynamics-76/2832095-change-model.html)
NEVER-REST 04-01-2005 04:58 PM
change model
Can a control line stunter be changed wing wise to conform to a fun flyer if the correct aerodynamic`s are implemented I have a great shaped plane and plan to work from and can build are there snags I`m not seeing.What type of aerofoil would best suit this type of set up
Gremlin Castle 04-01-2005 10:21 PM
RE: change model
1 Attachment(s)
Controline stunt planes have been modified into RR planes for years. I have a Veco Thunderbird with a fourstroke OS 50 in it and it is a great sport flyer. Used the flaps for ailerons and put a live rudder and steerable tailwheel on it and balanced it just as it would have been as a controliner. It flys great and not much faster than it would have as a controline model. Loops can be made fairly tight and the rolls are fairly axial but a long way from pattern quality. Landings are about controline speed.
As far as making the wings equal length it helps but is not an absolute necessity. Build it straight and balance it properly and it will most likely fly well.
Here are some belated pictures of the Thunderbird as described above.
ORIGINAL: NEVER-REST
Gremlin Castle 04-27-2005 07:53 PM
RE: change model
I will try to get some flight photos posted this next week
50+AirYears 04-28-2005 07:15 PM
RE: change model
In fact, sometime in the late 50s, either Ken Williard or Bill Winter converted a Veco Brave to single channel RC, using a K&B 09 or 15. Whichever did it, he made both wing panels the same length, built the rudder with a hinge and installed the torque rod to let an escapement operate the rudder. He built the wing with about 6 or 7 degrees dihedral. Remember, Rudder Only. he would then put on shows where he would take off with a single control line wire attached to each wing tip, fly around in a circle for a couple laps as a tethered plane, then "accidently" drop the inboard wire, after which his assistant would take over control with the hidden transmitter. The original conversion of the Nobler to RC was covered in an American Aviation Modeler, after which Top Flite brought out the kit. Model Aviation still lists a plan sheet to convert Lew McFarland's Shark 45 to RC. I think Brodack models has an updated kit for this plane. Numerous issues of RCM have had articles on converting profile control line planes such as the Flite Streak to RC. For a while, Goldberg Models had a profile P-40 control line plane for 15 sized engines that had a section in the plans showing how to convert it to RC. Many of the Berkely scale kits were listed as multi-function, and could be built for RC or Control Line, and even Free Flight.
Not only can it be done, it has been done.
