RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Need some prop advice (https://www.rcuniverse.com/forum/aerodynamics-76/2909759-need-some-prop-advice.html)
Enkidu 04-24-2005 09:12 PM
Hello everybody,
I'm working on a large scale project and need some advice on props. The base engine is a 3hp 4 cycle. What would be the advantages or disadvantages of running a 4 bladed prop vs. a 2 bladed prop on an engine as large as this?
BMatthews 04-26-2005 01:26 AM
RE: Need some prop advice
None as far as power to airflow conversion is concerned.
The number of prop blades has been a popular topic over the time I've been here. Basically 2 is best and 3 or 4 is used when other factors overpower the need for the maximum efficiency. Things like noise control for pattern models, ground clearance and scale factors being the biggies.
Mechanos 04-26-2005 07:17 AM
Is there a formula for calculate what 3 or 4 blade prop is needed if you know what 2 blade prop to use?
adam_one 04-27-2005 04:53 PM
ORIGINAL: Mechanos
If you want to keep the same power consumption, the 3 blade prop diameter D3 = D2*.92
while the 4 blade prop diameter D4 = D2*.87
Mechanos 04-27-2005 07:31 PM
ORIGINAL: adam_one
ORIGINAL: Mechanos
I assume you are holding the pitch constant?
adam_one 04-28-2005 03:17 AM
Yes, that's assuming the same pitch and the same rpm.
