RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Wing span, weight, and engine size (https://www.rcuniverse.com/forum/aerodynamics-76/3405340-wing-span-weight-engine-size.html)
BillS 09-29-2005 09:36 AM
How much engine is needed to put a 100”span, 700sq in, 5 pound glider (Aerofly) in thermal territory? Does anyone have a web site address for the T-tail glider?
Thanks.
Bill
SST 09-29-2005 02:39 PM
RE: Wing span, weight, and engine size
I used to use a Cox Medallion .15 on one. Would pull loops from a hand launch! I would recommend the Norvel .15.
BillS 09-29-2005 07:36 PM
SST,
Thanks for the information. Is yours an Aerofly? Also how much weight do you have in the nose?
Bill
AgCat1982 10-09-2005 08:22 AM
I just recently completed an Aerofly for a friend on this forum. He wanted to go electric. I installed a brushless motor with plenty of power, it is just that the prop size is too limited by the engine placement. I flew it once before sending it to him. You can see it in my gallery. He also wanted me to put ailerons on it, which I did.
