RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   flying wing (https://www.rcuniverse.com/forum/aerodynamics-76/3407886-flying-wing.html)
max plank 09-30-2005 12:12 AM
flying wing
i buildt a flying wing with a os 15 la engine span 800 mm cord 250 mm profile mh46 reflexed airfoil.. wigth 600 gram emty
it is very stable too fly ( and fast) at first it hat a tendensy too dutch roll but i cut the tail down a littel and that eliminated the problem.
my remaining problem is wenn loop it very hard it will stall out of the loop. is there a solution too that, will making the tailerons tapper out too the tips help you think?
sorry fore my spelling %&/ยค
Dr1Driver 09-30-2005 05:35 AM
RE: flying wing
If any plane snaps out of a loop, it's actually stalling the wing. Some airfoils simply won't loop tightly. Two solutions you might try is more speed and/or less elevator.
Dr.1
3dbob37n 09-30-2005 01:29 PM
RE: flying wing
Or, a more powerful engine to pull it on through the loops. With enough power, most anything will get through a loop.
3dbob
