RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   V tail design (https://www.rcuniverse.com/forum/aerodynamics-76/3448040-v-tail-design.html)
MJD 10-12-2005 10:37 AM
V tail design
Hi guys,
I know V-tails are usually designed with 110 degrees dihedral to provide a good balance between effective horizontal and vertical areas. One question though - when sizing the surfaces do I simply use projected area, i.e. if I want a 22% stab do I simply design the projected top view of the V-tail to have 22% of the wing area? Seems intuitive but thought I'd ask anyway.
Thx
MJD
HighPlains 10-12-2005 11:26 AM
RE: V tail design
They may be built that way, but that's not "designed".
Tall Paul 10-12-2005 11:42 AM
RE: V tail design
http://www.charlesriverrc.org/articl...tailsizing.htm
MJD 10-12-2005 02:05 PM
RE: V tail design
Re: http://www.charlesriverrc.org/articl...tailsizing.htm
That's handy, thanks!
Re:
Well, sure it is, but the designer might not have employed any engineering. Anyhow, for stab areas of 20-25% 110 degrees yields a functional though perhaps not ideal vertical stab area, so I suppose that is why it is one of those old rule of thumb principles.
MJD
HighPlains 10-12-2005 04:40 PM
RE: V tail design
You see 110 degrees because people copy without trying to comprehend. Beech use 118 degrees on the Bonanza. Gliders usually need the more acute angles.
typicalaimster 10-12-2005 09:56 PM
RE: V tail design
If your lazy, like me, I have a [link=http://www.zwei.net/designs/Misc%20Stuff/TailAngle.xls]spread sheet[/link] that will help you find the angle. It follows the formula found in another discussion.
MJD 10-13-2005 09:03 AM
RE: V tail design
Thanks! I'll do the calc myself so I (hopefully) remember how next time, but I'll keep that handy anyway.
MJD
kriegsmacht 10-13-2005 11:25 AM
RE: V tail design
ORIGINAL: HighPlains
Tall Paul 10-13-2005 12:40 PM
RE: V tail design
ORIGINAL: kriegsmacht
I think it's a reference to the 110 degrees, which is commonly seen.
Johnny uses 110 degrees, so I will too..
Without knowing -why- the 110 degrees is used, it's not "design".
The vee-angle is predicated on the airplane use.
A rudder-elevator airplane might use 90 degrees, for the most effective rudder response.
An aileorn plane which doesn't use the rudder as the primary turning control can relax the vee to 110 degrees, giving the elevator more authority.
