RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Approximate payload for a Eagle 2 (https://www.rcuniverse.com/forum/aerodynamics-76/4651-approximate-payload-eagle-2-a.html)
FHHuber 07-16-2002 06:51 PM
Field altitude and runway available? At high altitude, especially with a short runway on a hot day... 0 payload. ;)
You SHOULD be able to lift 2 lbs of payload under normal conditions... but take-off will be trickyer than normal. If you have the right facilities (paved smooth runway... lots of room and no trees...) and good conditions (cool day... at seal level) you might lift 5 lbs. :eek: But then the plane would barely be able to climb...
FHHuber 07-19-2002 06:57 PM
Play it safe... work up the amont you lift in gradual amounts. The plane wll respond differently with the increase in load. Add the first pound (appx .8 kilo) one flight, then about half that much more...
Take-offs and landings are a pain at max payload...
