RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Aileron Length (https://www.rcuniverse.com/forum/aerodynamics-76/5675493-aileron-length.html)
Rflyin 04-06-2007 04:19 PM
Aileron Length
Hello All,
I fly a 64" wing on my combat planes with 30" ailerons, inch and a half wide. 1 servo mounted in the center of the wing. I want to play with putting 2 servos in the wing one for each aileron to get better roll rate. My question is how short can I make my ailerons. I know ailerons are most effective near the wing tip but at what point do they become just drag as they get near the fuse.
Rick
MinnFlyer 04-06-2007 07:34 PM
RE: Aileron Length
I don't know the scientic formula, but I can tell you this:
On several planes with strip ailerons, I have cut the inner 1/3 off to use as flaps and it made no noticable difference in roll rate
Rflyin 04-06-2007 08:03 PM
RE: Aileron Length
Thanks Minnflyer,
That was going to be my first guess if not given something more concrete. Btw I liked your write up on the Skybolt, I'm building one now.
Rick
