RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Duraplane trainer 20 stall problem (https://www.rcuniverse.com/forum/aerodynamics-76/761982-duraplane-trainer-20-stall-problem.html)
C. McManamay 05-10-2003 04:53 PM
I have a duraplane trainer 20 it flys ok but in a turn sometimes is seems if you bank it to far it well stall and go into a spin. I have been able to pull out of the spin but just before it gets to the ground. Has any body had this problem with a duraplane. I built it four channel. Could it be do to to much control movement or cg. in wrong place? Any help would be appreciated.
Tattoo 05-11-2003 09:34 PM
Sounds tail heavy to me.
