RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   digital wind tunnel (https://www.rcuniverse.com/forum/aerodynamics-76/8372417-digital-wind-tunnel.html)
Lafayette 01-18-2009 02:02 PM
digital wind tunnel
Hi guys please give me links to free or demo versions of digital/virtual wind tunnels
I am trying to make my own airfoil or test other airfoils. I want to have a program where I can plot my OWN airfoils and load existing airfoils and test them under certain conditions and angles of attack. The information I want to get from these tests is at what point along the wing EXACTLY does the boundary layer separate and how much lift and drag the body i drew produces- I would like to draw not only airfoils but other shape like fuselage shapes, but if only airfoils are allowed then fine.
PLEASE guys if you know of such programs then I would appreciate youd leave a comment with their name.
Lafayette, thanks.;)
All Day Dan 01-18-2009 02:17 PM
RE: digital wind tunnel
I use Compufoil.com. Dan.
MikeChilson 01-18-2009 05:51 PM
Try MicroCFD...
http://www.microcfd.com/
Will take some time to get up to speed but will do everythign you need.
BMatthews 01-18-2009 09:21 PM
I mentioned Xfoil as supplied with Profili2 in the other thread. For airfoil designing that's the one you want. It won't show you the air actually flowing over the wing but it provides you with pressure distribution curves and Cl vs Cd curves.
Also have you checked the links provided in the sticky threads at the top of the listings? There's lots of good info out there that is linked in that thread.
