Thrust Stand
I have been looking around to find any information on engine thrust stands and have not been able to find anything useful. Does anyone know of any companies who manufacture a thrust stand for RC glow engines? Thanks in advance for your help.
RE: Thrust Stand
When we've needed/wanted to play with one, we made it. Ball-bearing supported mounting plate, pulling against the most accurate fish scales we could get ahold of. Even though only remotely accurate, we thought we would benefit mainly from the difference in thrust from prop to prop tested. We learned quickly however, that static thrust numbers mean little when you try to apply your findings to dynamic flight characteristics. The thrust test stands have sat idle pretty much ever since.
RE: Thrust Stand
1 Attachment(s)
Thrust stands are good for finding relative performance of engnes /props .
My own stand was designed (and copied by others ) by me to find power consumption vs thrust on electric motors . it could be adapted for glow but basically the informtion really needed canbe done with a pull scale on a plane. we used this technique to determinstatic thrust and relative power using differing exhaust setups -mainly tuned pipes. |
RE: Thrust Stand
Thanks for the replies, i have seen many like the picture posted, and have already designed one like it in solid works, but due to different time constraints I was trying to find one that someone sells so that I do not have to make one. Let me know if there are any manufactures out there. Thanks.
RE: Thrust Stand
Smitty- years back-in 1977 we had a flying field in Loveland - the Propbusters Club.
the farmer sold the farm ind in a heartbeat - the field was no more I had just started making my Tiporare models -Dave Brown flew one and atthe time Bill Keller was making the fuselages up in Dayton. |
RE: Thrust Stand
ORIGINAL: dick Hanson Smitty- years back-in 1977 we had a flying field in Loveland - the Propbusters Club. the farmer sold the farm ind in a heartbeat - the field was no more I had just started making my Tiporare models -Dave Brown flew one and atthe time Bill Keller was making the fuselages up in Dayton. |
RE: Thrust Stand
ORIGINAL: smitty5688 I have been looking around to find any information on engine thrust stands and have not been able to find anything useful. Does anyone know of any companies who manufacture a thrust stand for RC glow engines? Thanks in advance for your help. |
| All times are GMT -8. The time now is 10:47 AM. |
