Go Back  RCU Forums > RC Airplanes > Aeroworks Vendor Forum
Reload this Page >
Mark: Question about Extra 30cc build
Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
Old 07-30-2011, 06:15 AM
stevehookem
Default Mark: Question about Extra 30cc build
Do I leave the 30cc drill guide plate in front of the firewall and sandwich it between the stand-offs? The firewall look pretty thin on it's own. The DLE manual says "at least 3/8" thick for a firewall. I haven't measured but the firewall appears 1/4".
stevehookem is offline
Old 07-30-2011, 08:45 AM
Mark Dennis
Mark Dennis's Avatar
Default RE: Mark: Question about Extra 30cc build
Steve,
The template is meant to be removed after the holes are drilled. The firewall is very strong at its current thickness.
Mark
Mark Dennis is offline
Old 07-30-2011, 06:06 PM
stevehookem
Mark,
Just sent you a PM.
If I remove it, I am very far off from making the 6 1/2" firewall to prop hub distance. I would have to use 1/8" of washers (in addition to about 1/4" I already must use. I left it sandwiched between the stand-offs and the firewall. It's the same material as the firewall, right? It appeared to be ply. I then had to add about 1/4" of washers between the drill guide and the stand-offs.
In the manual, the photos don't appear to have any additional washers moving the engine forward. Did I do something wrong?
Old 08-30-2011, 11:12 AM
TIA
TIA's Avatar
So, what happend?
TIA is offline
Old 08-30-2011, 05:00 PM
stevehookem
I'm flying the heck out of it!
I left the drill guide on sandwiched between the stand-offs and the firewall. I only had to add about 1/8" of washers behind the stand-offs.
Amazing flyer, btw.
Old 09-02-2011, 01:51 PM
bemeson
bemeson's Avatar
How are the servos holding up...
Brian
bemeson is offline
Old 09-02-2011, 03:48 PM
stevehookem
So far so good! Other than the owner of a local shop here that "warned" me about them. He said "I'm not saying they're bad but just keep an eye on them". Of course, I didn't buy them from him so.....
Old 09-04-2011, 04:41 PM
bemeson
bemeson's Avatar
Well I have got about 100 flights on the 50cc and about the same on 30cc and they have held up nicely. I have a bunch of the micro metal gear servos on a 1400mm Airfield T28 and its been steller as well. Good luck and take care....call if you need anything.
Brian
bemeson is offline
