Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
Freestyle 53"
Old 05-30-2013, 06:10 AM
ktmfrank
Default Freestyle 53"
hi! I recently bought this model brand new here at AMR in QC.I have an issue while in flight it keeps pitching up while releasing the sticks. I trimmed I down a bit but the the elevator response is funky a bit.I check the CG as it balanced perfectly on the wing tube like its supposed to be?Any clues why it does that?
ktmfrank is offline
Old 05-30-2013, 06:52 AM
Mark Dennis
Mark Dennis's Avatar
Default RE: Freestyle 53
What servo are you using on the elevator? It may not be centering correctly causing the elevator trim to change. You can also try moving the CG forward 1/8", with the CG on the wing tube the airplane will have a very neutral CG and can become pitch sensitive at certain speeds.
Mark
Mark Dennis is offline
Old 05-30-2013, 06:55 AM
ktmfrank
Hi Mark !I'm using a hitec hs225 mg
ktmfrank is offline
Old 05-30-2013, 09:50 AM
ktmfrank
1.7* incidence on the stab is that normal?
ktmfrank is offline
Old 05-30-2013, 09:59 AM
Mark Dennis
The incidence is fine, I'd be more concerned with the weight of the 225 servo you are using, it is 1/2oz heavier than the HS85 that we recommend, on an airplane this size that will make a huge difference. Move the CG forward and go fly, that should solve your problem.
Mark
