Go Back  RCU Forums > RC Airplanes > Aeroworks Vendor Forum
Reload this Page >
36% KATANA PULL-PULL EXITS
Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
Old 02-10-2006, 10:55 PM
storklappe
Default 36% KATANA PULL-PULL EXITS
Mark,
Can you tell me the measurements for the center of the rudder pull-pull exit holes in the 36% Katana fuselage?
Some time ago, Rocco gave me the following measurements: from the back of the fuse, the slot center is 10.5" and the slot center up from the fuse bottom is 3.75". The problem is, if I make the hole up 3.75" from the bottom, the straight line back to the rudder will take the cables above the rudder hard points.
storklappe is offline
Old 02-10-2006, 11:02 PM
Mark Dennis
Mark Dennis's Avatar
Default RE: 36% KATANA PULL-PULL EXITS
Ok just went to the basement to measure mine the exit is 10.5 and 3.25 this should locate the horn on the hard piont. Let me know if it still won't line up.
Mark Dennis is offline
Old 02-11-2006, 07:20 PM
storklappe
Thanks Mark. I really appreciate your help!
Are the measurements you gave to the center of the slot?
Thanks!
Old 02-11-2006, 11:14 PM
Mark Dennis
Yes they are towards the center and you can also move it down a little if you need to in order to get it just right.
Old 02-11-2006, 11:32 PM
treedog
treedog's Avatar
may i ask what is the purpose of a pull-pull system and why is it even neccesary as im not into 3d yet and dont know how it all works
treedog is offline
Old 02-12-2006, 12:33 AM
Mark Dennis
Mainly it is to help balance the plane. Some will mount the rudder servo(s) in the tail if they can get it to balance. Either way works and really dosen't have anything to do with 3D.
Old 02-12-2006, 12:40 AM
storklappe
Thanks again Mark!
I have been worried about cutting the slot in the fuselage because I don't know if I'll be able to get the cable to come out the center of the hole without rubbing the top or bottom.
Old 02-12-2006, 10:27 AM
Mark Dennis
What i did was i took a tub and but it right where it exits so it dosent rub on the wood.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
