Go Back  RCU Forums > RC Airplanes > Aeroworks Vendor Forum
Reload this Page >
SHOULD I "SEAL-OFF" THE FUSELAGE?
Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
Old 02-13-2006, 03:29 AM
storklappe
Default SHOULD I "SEAL-OFF" THE FUSELAGE?
Hi Mark,
I am not using cannister mufflers. Should cover the inlet to this area so the fuse is sealed?
Thanks!
storklappe is offline
Old 02-13-2006, 05:21 PM
Mark Dennis
Mark Dennis's Avatar
Default RE: SHOULD I "SEAL-OFF" THE FUSELAGE?
Yes i did it just so no oil would leak into the fuse. I just used some covering on mine so it added little to no weight.
Mark Dennis is offline
Old 02-13-2006, 06:22 PM
storklappe
Mark,
I can't thank you enough for your help!
My next plane is going to be your 260. How does it fly compared to the 36% Katana?
Thanks again!
Old 02-13-2006, 06:35 PM
Mark Dennis
Well that is a very hard question to answer. The 260 is lighter than your Katana so that is a large part of it. For sequence flying I prefer the 260 as it has very little if any coupling and is lighter which means a better power to weight at my alltitude at sea leval you will have planty of power with both planes. I really like my Katana for 3D and all around fun which is why i am going to keep it together even after i finish the 260 and yak. So really if i had to pick one it would be the 260 since it will 3D and to imac like no other plane i have flown before.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
