Go Back  RCU Forums > RC Airplanes > Aeroworks Vendor Forum
Reload this Page >
Introducing the new 150cc Ultimate 20-300
Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
Old 12-14-2008, 07:47 PM
Mark Dennis
Mark Dennis's Avatar
Default Introducing the new 150cc Ultimate 20-300
Aeroworks is proud to add the New 150cc Ultimate 20-300 to their line of QUICK BUILD Series Aircraft
Designed by Jason Noll to provide the best performing Ultimate to date. The New Ultimate 20-300 has been designed to out perform any other Ultimate on the market. With minimal mixing and aileron differential required to achieve perfect flight, creates the truest flying Ultimate EVER! The 150cc Ultimate is a true QB offering High quality, light weight construction and fastest build time possible.
Aeroworks has Raised the Bar
The QB Series is top quality in both design and performance that has set the standard for the ARF aircraft market!
With the Ultimateā€™s unbeatable stability and precision flight characteristics it is certain to please both the beginner as well as the advanced competitor
Designed for both precision and 3D style flying this plane is sure to out perform all other aircraft.
The Ultimate was designed from the ground up to be a top performing aircraft. Generous control surfaces and an awesome power to weight ratio make this a plane you'll want to fly every visit to the field!
SPECIFICATIONS
Wing Span 94 inches.
Wing Area 3250 sq. in.
Fuse Length (Rudder to Front of Cowl) 107"
Fuse Length (Rudder to Front of Spinner) 113.5"
Cowl Width 15"
Weight 41 to 42 lbs
Engine 150cc
Radio 8 Channels minimum
FEATURING
Strong Light Weight Construction
Complete and Detailed Instruction Manual on CD
Carbon Landing Gear
Carbon Tail Wheel
Complete High Quality SAE Hardware Package Included
Adjustable pushrods with Centering Nut
Machined aluminum engine stand offs included
Carbon Reinforced Wing Spar Design Increases Wing Strength and Eliminates the Need for Flying Wires
No Flying Wires Required for Wings or Stabilizer Speeds Assembly at the field
Pre Installed Center Cabane
Carbon Wing and Stab Tubes
Professionally covered in ULTRACOTEā„¢
Pre-Hinged from factory (Ready to Fly)No gluing
One Servo Wing
One Servo Elevator
Large control surfaces double beveled for maximum throw
Pre Mounted Fiberglass Cowl and Wheel Pants
Flush Fit Cowling with No External Mounting Bolts
Pre Mounted and Tinted Canopy
Pre installed and fuel proofed engine box
Laser cut engine mounting templates provided
Custom Throw MeterIncluded
Extra Ultracoteā„¢ covering provided for small repairs
Two Fuel tanks One for Smoke
12 to 14 Hours assembly Time
Expected Delivery Late Feburary 2009
Pre-Order Today!
More pictures [link=http://aero-works.net/store/detail.aspx?ID=351]here[/link], look for the video and manual coming soon!
ID:	1089667   Click image for larger version
ID:	1089668   Click image for larger version
ID:	1089669   Click image for larger version
ID:	1089670   Click image for larger version
ID:	1089671   Click image for larger version
ID:	1089672   Click image for larger version
ID:	1089673   Click image for larger version
Mark Dennis is offline
Old 12-14-2008, 07:54 PM
Sukhoi4Me
Default RE: Introducing the new 150cc Ultimate 20-300
Ummm.... WOW!!![sm=biggrin.gif] Might just be my first 40%+!
Sukhoi4Me is offline
Old 12-14-2008, 10:55 PM
Efishensea
My Feedback: (15)
You Guys are killing me! That's a Beautiful Airplane, I guess I have to pull a second on the House now.
Efishensea is offline
Old 12-17-2008, 01:52 AM
jerrysu29
I just started on my Aero-Works 85cc Yak I had a friend pick up for me, just before Thanksgiving. Last Week I sold a 100cc Sukhoi RTF. I was planning on ordering the 150cc Yak QB (new color scheme) now you guys come out with this cool bipe. I've had the chance to fly the H9 Bipe, NICE. Know I'm totally confused thanks Mark, LOL!!! jerrysu29 Call Sign Wild Man
jerrysu29 is offline
Old 12-28-2008, 05:08 PM
reyn3545
reyn3545's Avatar
I give up... I can't resist!
I was trying to decide between a jet and the 150cc Ulti for my 50th birthday present... luckily, the birthday is in February!
I've got everything to go in this plane, 3W 170, cans, all the servos, etc... just need to pull them out of my H9... looking forward to that project!
Don't be late, Rocco!
reyn3545 is offline
Old 12-29-2008, 02:21 AM
bodywerks
bodywerks's Avatar
call me jealous!
bodywerks is offline
Old 12-29-2008, 05:54 AM
jsm77777
Any plans in the works for a 100cc version? Scott
jsm77777 is offline
Old 01-03-2009, 06:52 PM
Fred
My Feedback: (21)
Fred's Avatar
Sure would like to see it in action,,
Fred is offline
Old 01-03-2009, 08:59 PM
Mark Dennis
ORIGINAL: Fred
There will be a video posted to the website soon.
As for the 100cc version, its in the works.
Old 01-03-2009, 09:03 PM
reyn3545
reyn3545's Avatar
Do you know off hand if the canister tunnels will take standard 60mm thick cans?
reyn3545 is offline
Old 01-07-2009, 09:39 PM
DLEVETT
My Feedback: (13)
ORIGINAL: Mark Dennis
ORIGINAL: Fred
How about a 75-85cc version?
I,ve got a 75cc Extra but the Ultimate for my DA85 would be just that!
DLEVETT is offline
Old 01-07-2009, 10:43 PM
Bdegan
Bdegan's Avatar
ORIGINAL: DLEVETT
ORIGINAL: Fred
There is mention around here or somewhere I read recently of a 100cc version in the works, due possibly in the fall.
Put your 85 on a pipe [>:] Makes as much power as a 100cc
Bdegan is offline
Old 01-11-2009, 08:45 PM
reyn3545
reyn3545's Avatar
I see the AW website has the assembly manual posted now for the 150cc.. looks like the typical very clean AeroWorks build. Great selection of motor templates, even a custom spacer for the DA150. Looks like PLENTY of room in the fuse, even with a canister tunnel taking up part of it. mounting brackets are included for both canisters and pipes, and there are removable hatches to access the tunnel during the build and later for maintenance.
One of my biggest complaints with canisters has always been actually getting the compression clamps on the adapters.... it looks like they are easily accessable from the bottom of the fuse.
my only "dig" on the model from looking at the book, and it's been a dig on every AW plane I've owned.... is the main wheels. I land on paved surfaces (well, I try to), and those solid foam wheels can get chewed up in no time, especially on a plane this heavy.
Still looking for the flying videos... I know these things take time, especially with the holidays.
My build table is cleared off, it's too cold and windy to fly, and folks are trying to buy my H9 bipe already..... let's get the planes into the US fast!
reyn3545 is offline
Old 01-13-2009, 07:51 PM
kochj
Why does this plane look small??
It looks like the same size as a 100cc python...
Is that due to the scale? Is a pits python a bigger plane and therefore bigger when scaled down?
kochj is offline
Old 01-13-2009, 08:03 PM
reyn3545
reyn3545's Avatar
I think it"s a 42%, as opposed to the H9 46%... weights seem pretty comparable, but AW's have always been a little on the heavy side.
reyn3545 is offline
Old 01-14-2009, 05:29 PM
Danny Baker
The 20-300 offering from AW is 40.2% or 38.2% depending on which version of the full scale 20-300 the model was scaled from.
Danny Baker is offline
Old 01-14-2009, 09:27 PM
reyn3545
reyn3545's Avatar
Either way... it oughta be a rocket with a 170 on the nose!
reyn3545 is offline
Old 01-19-2009, 04:04 PM
kochj
Can you say..... No Shivick????
That would be lot's of fun....
kochj is offline
Old 02-19-2009, 11:48 AM
Aero-Works
Aero-Works's Avatar
Hello Everyone,
Ultimates are now In Stock and Shipping. If we have not yet contacted you on your pre-order be sure to give us a call so you will not miss out on this first shipment. The planes are moving fast!
I would like to thank everyone for your continued support to Aeroworks and our QB product line.
Thank You
Rocco
Aeroworks / Owner
Aero-Works is offline
Old 03-01-2009, 10:21 PM
kochj
would a 220 twin fit in this one??
I am leaning twards the NEW 3w 220 4cyl
or the 3M Mintor 220 4-cyl?
ID:	1148200   Click image for larger version
ID:	1148201   Click image for larger version
ID:	1148202   Click image for larger version
kochj is offline
Old 03-02-2009, 10:37 PM
Aero-Works
Aero-Works's Avatar
With out knowing the specifications for either the 3W or the Mintor I am not certain how they will fit. If you give us a call we can give you the exact inside dimensions of the cowling. I would think they would fit but the engine box length might be a little long. You may have to cut it to fit the longer engine
Thank You
Rocco /Aeroworks
Old 03-23-2009, 03:34 PM
butternifedge
any assembly threads going yet? Can't really call a highly fabricated QB a build thread you know. Bet the new DA200 4 cyl. would sound great!!
butternifedge is offline
Old 04-12-2009, 11:20 AM
Luv2rcfly
To Aero-Tech support:
I'm planning on getting this plane next week.
My concerns are the control arms using what looks like screws with
thick ca glue.
Will this be strong enough for all out 3-D?
Last thing I need is for the screws to rip out...
Is this config done on Jason's 20-300?
thanks,
Steve
Luv2rcfly is offline
Old 04-24-2009, 02:20 PM
Galaxy 3D
My Feedback: (-1)
Galaxy 3D's Avatar
Sorry, I put these pics in the wrong thread. Here is mine with a 3W 220 installed. We are going to run it today. I mounted 4 servos in the tail for the rudder so I think my CG should come out close.
ID:	1186479   Click image for larger version
ID:	1186480   Click image for larger version
Galaxy 3D is offline
Old 04-27-2009, 10:14 AM
bodywerks
bodywerks's Avatar
ORIGINAL: Luv2rcfly
thick ca glue.
thanks,
Steve
Surely, you mean't Aeroworks support ...Aero-tech might as well be a four-letter-word.
As far as the control arms are concerned, they are steel so they aren't going to break. The area they mount to is ply, top and bottom, and solid balsa as a filler. There are 6 screws attaching each control horn set. I have the 42% 260 with just one servo per elevator, two per wing, and a push-pull on the rudder and have never had a problem in over a year of flying. Bottom line is that there is nothing to worry about here.
My suggestion, however, is to first tap the holes with a dry screw, then wick thin CA into the holes instead of just putting a drop of thick CA on the screw and inserting it. The thin CA definitely makes for a stronger threaded hole.
One thing that you might consider for even more assurance, is to switch out the supplied screws for Dubro #4 screws or #3 servo screws from microfasteners. One reason for this is because they are allen head screws instead of phillips, but they are also a higher quality screw.
Also, if you want to go to the trouble of installing Dubro or Hangar 9 style arms with the threaded rods all the way through the control surface you can do so.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
