RCU Forums
-   Aeroworks Vendor Forum (https://www.rcuniverse.com/forum/aeroworks-vendor-forum-528/)
-   -   engine vibration (https://www.rcuniverse.com/forum/aeroworks-vendor-forum-528/10928901-engine-vibration.html)
cbron 01-26-2012 10:11 AM
engine vibration
I have the 30cc aw extra 300 with a dle 30. I am getting a lot of vibration at low speed. Mid range and wide open seem fine but at idle its bad. Any suggestions? Thanks a lot
Zippi 01-26-2012 01:55 PM
RE: engine vibration
ORIGINAL: cbron
Have you balanced your prop?
cbron 01-26-2012 03:21 PM
yea recently put a zoar 20-6 on it and it balanced perfect.
speedracerntrixie 01-26-2012 04:08 PM
Did you balance the prop hub? Spinner? Are you doing test runs with the wings off?
Mark Dennis 01-26-2012 05:11 PM
ORIGINAL: cbron
How is it running at idle? A rich low end can cause the motor to vibrate more. Balancing the spinner and the hub of the prop will also help.
Mark
cbron 01-26-2012 05:56 PM
Thanks mark sounds like it may be rich on low end. Runs great though with good transition. Also the spinner I got was an aeroworks. Those are balanced when you get them right?
