Instruction manual 35% aeroworks yak 55
Does anyone have the CG for this plane. I cant find a manual to download
C OF G AW yak55
I have the 35% yak 55 too - the manual states cog is 3.75" -4" from the leading edge at the wing tip.
I balanced mine at rhe chord where the wing tube is located and required no trim at all in flight. Have manual pdf if you need it sent to you |
Looking for this manual, does anyone have the pdf squirreled away? Thanks
The cord wing/tub is a great place to start
Originally Posted by gbrady
(Post 12795956)
Hi,
The standoff I used was DLE 55 RA 68mm Also here's a link for the manual that will help you Thanks, Gary Brady https://manualzz.com/doc/23452445/50cc-yak-55m-manual |
Thanks for taking the time to try and help out, unfortunately the manual/info I'm after is for the 35% (100cc) version.
