LANDING GEAR BOLTS
Hi Mark,
The instructions for my 36% Katana say to use 10-32 bolts to attach the landing gear to the fuselage. Troble is, my landing gear came came with holes already drilled that are way bigger than 10-32. Should I find bolts the size of the holes in the landing gear? The holes are 21/64" Also, I have been told to use 1/4" axles vs. 3/16" axles -- what size would you go with? |
RE: LANDING GEAR BOLTS
You can make a spacer to fit in the landing gear holes and let the 10x32 bolt fit inside the spacer.
Tony |
If the gear is bigger you could put in a spacer or just use bigger bolts. Either way will work fine but remember to use good bolts and blindnuts.
ORIGINAL: storklappe Snip Also, I have been told to use 1/4" axles vs. 3/16" axles -- what size would you go with? |
