RCU Forums
-   Aeroworks Vendor Forum (https://www.rcuniverse.com/forum/aeroworks-vendor-forum-528/)
-   -   Misaligned Elevator Halves (https://www.rcuniverse.com/forum/aeroworks-vendor-forum-528/5414152-misaligned-elevator-halves.html)
storklappe 02-13-2007 04:38 PM
Mark,
On my 36% Katana, when I have the elevators zeroed (lined up) with each other (as viewed from behind the plane), one elevator half's counter balance does not line up with the stabilizer. The counter balance is below the stab by between 3/16" and 1/4".
Was yours off like this?
I am not sure what to do. My experience with flying a plane that has something crooked is that you can trim it for one speed and it will fly great, but when speed changes, the trim will be off.
I called the shop today and your Dad said I should try to fly it and he also suggested that I call you to see what ideas you may have. I am reluctant to fly a plane when something is this far off.
Thanks!
Mark Dennis 02-13-2007 10:12 PM
RE: Misaligned Elevator Halves
The biggest thing to remeber is to keep the overall surface alighned, as long as the trailing edge of both surfaces are straight with each other thats all that matters. As long as you do this you will not notice it in the air.
