Go Back  RCU Forums > Classifieds & Marketplace > Airplanes - All types
Reload this Page >
Great Planes Escapade New $120
Airplanes - All types View all types of airplane ads here. Includes Kits, ARC''s, ARF''s, and RTF
Old 02-17-2024, 04:11 PM
Desert__Flyer
Default Great Planes Escapade New $120
New in box
A pilot might own many planes, but there's always one that stands out as the all-time favorite. That's what Great Planes designed the Escapade GP/EP ARF to be. If you've mastered a trainer, you can fly it with confidence - and when you've flown it once, you'll always be eager for the next chance to enjoy its easy handling and nimble aerobatics.
o Easy-to-install mounts for glow engines and brushless motors
o No-mod set ups for single-servo or dual-servo ailerons
o Built-up airframe
o Bolt-on wing and tail surfaces, landing gear and wheel pants
Key Features
o Construction: Balsa and ply
o Covering: Covered in Top Flite MonoKote
o Wings: One-piece with aluminum joiner tube
o Aileron Control: Modeler's choice of single or dual servo control
o Radio Compartment: Plywood reinforced
o Canopy: Single tinted, hatch attaches to fuselage with magnets, preinstalled painted pilot bust
o Fuel Tank: 9.1oz (270cc)
o Landing Gear: Left and right aluminum sections 0.12" (3mm) thick
o Wheels: Main, foam 3" (76mm) diameter, tailwheel 0.87" (22mm) diameter
o Wheel Pants: Painted fiberglass
o Spinner: Plastic, red in color 2.5" (63mm) diameter
o Engine Mount: Two-piece composite
o Motor Mount: Plywood
Specifications
o Wingspan: 52.5" (1340mm)
o Wing Area: 483 sq in (31.2 sq dm)
o Weight: 5.0 - 5.5lb (2270 - 2495g)
o Wing Loading: 24 - 26 oz/sq ft (73 - 80 g/sq dm)
o Length: 46" (1160mm)
o Airfoil: Semi-symmetrical, low wing configuration
o Center of Gravity: 2-1/2" (63mm) Back from the wing's leading edge at the fuselage sides.
o Control Throws- Low Rate / High Rate
o Ailerons: Up & Down 1/4" (6mm) 11 / 1/2" (13mm) 22
o Elevator: Up & Down 3/4" (19mm) 15 / 1-1/4" (32mm) 25
o Rudder: Right & Left 1-1/4" (32mm) 17 / 2" (51mm) 26
Will Quote Shipping
Thanks Jim
Desert__Flyer is online now
Old 03-01-2024, 08:49 PM
Mustang Joe
Shipping to 11721
Mustang Joe is offline
Old 03-10-2024, 03:18 AM
Pilot379
Still available? What is shipping costs?
Thanks Pilot379
Pilot379 is offline
