Setting up DX6 Transmitter to control smoke flow on Sullivan Smoke Sys
Just needing to know procedure to set up flow rate on DX6 transmitter. Want smoke pump to vary flow according to engine RPMs. Less waste of fluid this way. Ive seen it done, but need a step by step procedure in setting up transmitter. Have already set up on off/on switch on trans, just need to control flow. Thanks
Im goin to try that shortly. So my master on off switch will still shut it off and on but when I go above 50% on throttle, the flow will start at whatever the offset rate is, correct?
